Cold water dripping on my feet?
Old Jul 17, 2004 | 07:27 PM
jdub db8's Avatar
Default Cold water dripping on my feet?
Ok, so i get my a/c fixed. Works pretty good but now i get cold water dripping on my feet (right foot) whie i am driving......UgH!!
Old Jul 17, 2004 | 08:25 PM
Smeeg Heed's Avatar
Default Re: Cold water dripping on my feet? (Jester_Si)
I had exactly the same problem and fixed it a few days ago. Sounds like your condenser drainage hose is blocked.
You can find it behind the glove compartment on the passenger side. Put your hand up the back there and feel around for a flexible rubber hose that goes into the firewall. Make sure there are no kinks in it (that was my problem). Otherwise there might be something stuck in there, which I'm not sure how to fix.
Old Jul 18, 2004 | 06:31 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Cold water dripping on my feet? (Smeeg Heed)
https://honda-tech.com/zero...06224
Old Jul 18, 2004 | 05:07 PM
stumpyf4's Avatar
Yea the drainage hose is blocked, could be dried leaves and **** in there. Pick up in there with a coat hanger.
P.s. evaporator not condenser, condenser is in the front of the car ontop of the radiator.
Old Jul 18, 2004 | 07:53 PM
jdub db8's Avatar
Default Re: Cold water dripping on my feet? (Dogginator)
You said in your other post it will probably drain about a quart of water.....i guess this explains the stale *** smell of my a/c
Old Jul 19, 2004 | 04:24 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester_Si &raquo;</TD></TR><TR><TD CLASS="quote">You said in your other post it will probably drain about a quart of water.....i guess this explains the stale *** smell of my a/c </TD></TR></TABLE>
Quite possibly. I was surprised by how much came out.
mac_24_seven
Dec 29, 2008 01:27 AM
EG9_808
Sep 1, 2008 06:16 PM
Revolver123
Honda Civic (2001 - 2005)
Jun 14, 2008 05:01 PM
blinger
May 14, 2007 06:39 PM
jakers
Dec 17, 2004 06:37 PM
