Engine Building Advice??
Im tring to put together a all motor B18a non vtec crx and i want it to run on pump gas what kind of comp ratio u think id have?and do u think it will work?
You guys are the fisrt people id trust with my motor.
B18a Motor
Ctr Pistons
Eagle H Beam Rods
Blanced Crank
Crower 404 Cams
Crower DUAL SPRING & TI RETAINERS
mild p&p
head milled .20
B18a Motor
Ctr Pistons
Eagle H Beam Rods
Blanced Crank
Crower 404 Cams
mild p&p
head milled .20
if the head and block are not milled then you should be around 11.4:1 which is perfectly fine on pump gas with tuning.
this is according to c-speed racing compression calculator.
http://www.c-speedracing.com/h...c.php
