All Techs: Please help, getting unwanted check engine light
Old Nov 24, 2001 | 07:50 AM
BeanRacer's Avatar
New User
Default All Techs: Please help, getting unwanted check engine light
My check engine light goes on every time. I start my car and drive, after a few miles the light goes on. I checked it and it was code 3 aka map sensor and also I was getting the code for the VSS aka vechicle speed sensor. I replaced the map sensor but code 3 showed up again. I don't know what to do with the speed sensor. What should do? Also:
I ran 14.3 on stock tires, aem and exhaust. The check engine light went off and I was never able to run or beat 14.3 again. Any suggestions? Any advice?
Can these codes affect my 1/4 times?
Old Nov 24, 2001 | 07:53 AM
VaporTrail's Avatar
New User
Default Re: All Techs: Please help, getting unwanted check engine light (BeanRacer)
I would do a continuety check on all related map sensor wiring. Check the clip also to make sure it's not damaged, or coroded. You don't have any sort of fuel computers installed, do you?
Old Nov 24, 2001 | 07:56 AM
FAST4DR's Avatar
Default Re: All Techs: Please help, getting unwanted check engine light (VaporTrail)
Have you checked the VSS ? Is the speedo working correctly? If so, check for poor connections or loose wires. I take it you are not under warranty anymore?
[Modified by FAST4DR, 5:03 PM 11/24/2001]
Old Nov 24, 2001 | 08:36 AM
Batoutahell's Avatar
I had a v-afc that caused MAP sensor codes on my car. Check your continuity of power/signal/ground at the plug and at the sensor itself, and also at the ecu.
Old Nov 24, 2001 | 08:38 AM
FAST4DR's Avatar
Default Re: All Techs: Please help, getting unwanted check engine light (Batoutahell)
Yes, can you provide a bit more info. It is hard to diagnose a problem if there are too many unknowns. Do you have a VAFC? Mods?
Old Nov 24, 2001 | 08:54 AM
Jracer1's Avatar
Default Re: All Techs: Please help, getting unwanted check engine light (FAST4DR)
Do you have a V-AFC or Field Vtec controller unit?
[Modified by Jracer1, 12:55 PM 11/24/2001]
[Modified by Jracer1, 12:56 PM 11/24/2001]
Old Nov 24, 2001 | 08:59 AM
BeanRacer's Avatar
New User
Your assumption is correct: the car is not under warranty. I do have a Field Vtec controller. Can it be loose wiring? I check the sensors and it seemed that they were fine.
Old Nov 24, 2001 | 09:00 AM
BeanRacer's Avatar
New User
How can I see if the speedo is working correctly?
Old Nov 24, 2001 | 09:01 AM
BeanRacer's Avatar
New User
I do have a Field Vtec controller unit
Old Nov 24, 2001 | 10:13 AM
FAST4DR's Avatar
Ok, was the MAP sensor bad? Do you know that for sure? I have heard of others with the Field unit tripping codes, too. And you KNOW that your performance is different or you THINK that it is? Make sure it's not just a psychological assumption because you see that shiny light. I am pretty sure it has to do with your controller.
Old Nov 24, 2001 | 11:15 AM
BeanRacer's Avatar
New User
My hat goes off to you GUYS!! You were 100% right. I examined the Field unit and the wires came loose. The Butt connectors didn't hold too well. So I just used twisted the wires together and mended them up with 3M electrical tape. I thank all my fellow import brothers. Job well done. Thanks for all your advice. I'm so happy I can rely on HT to get the job done instead of some mechanic specializing in *** f**king.(Exageratted pricing)
[Modified by BeanRacer, 3:17 PM 11/24/2001]
ProjectTib
Apr 28, 2007 08:11 AM
vw eater
Jan 4, 2007 04:45 PM
MIZIKETSK
Jun 15, 2004 06:36 AM
thashadow
Jun 12, 2002 05:00 PM
