Swap Problem
Old Jul 17, 2004 | 11:53 AM
The Mista Mike's Avatar
Default Swap Problem
I posted this in the Prelude forum but no one has responded so I figured that someone here may have some secondhand knowledge or something about this:
I have a buddy with a 94 Prelude who needs help. He did a swap to a 98 JDM SH engine after he hydrolocked his, and since then, his car idles funny, bouncing from about 800 to up near 2000 in a steady pattern. We tried unhooking the IACV (or whatever plug is at the throttle body) to see if that was the problem but it didn't end up working. Just threw a code and stalled the first time. The only thing that we noticed when it was off was it bogged down to around 600 and didn't goes as high but it still occurred in the same pattern.
Has anyone had any problems like this? Searches on HT have revealed nothing other than vacuum leaks as the sources, but I'm just wondering if anyone else has had this happen and what they did to fix it.
Old Jul 17, 2004 | 03:40 PM
Default Re: Swap Problem (Mistamike17)
bumpizzle
Old Jul 17, 2004 | 08:54 PM
No one?
Old Jul 17, 2004 | 09:18 PM
hatchi's Avatar
did you see if there are any vacuum lines that are not connected??
Old Jul 18, 2004 | 10:33 AM
Default Re: Swap Problem (hatchi)
Looks to me like everything is connected. There's a sensor that they're just running a circuit on with a piece of wire... looks pretty ghetto, but I dunno...
Old Jul 18, 2004 | 11:16 AM
REWURKD's Avatar
MAP sensor, egr valve its one of those 2
Old Jul 18, 2004 | 04:41 PM
Default Re: Swap Problem (REWURKD)
Does the 98 H22a SH ed. have an EGR valve?
Blue94preludeSi
Jun 15, 2008 06:39 PM
ph0on
Feb 2, 2007 06:06 AM
crxmike420
Mar 13, 2006 03:16 PM
The Mista Mike
Jul 16, 2004 08:04 PM
