which injectors?
Old Jul 17, 2004 | 10:29 AM
dat_flip's Avatar
Default which injectors?
My set up:
LS/VTEC, PR3 Pistons, B16 Head, GSR Valve Train, GSR Cams, AEBS Intake, Stock GSR Throttle Body, P73 ECU, B&M FPR, and BBK 255lph fuel pump
I just wanted to know which injectors I should use. I have 240's and 290's. Is it safe to just use the 290's with the GSR cams, because I plan on upgrading to CTR valvetrain in the future. Or should i use the 240's until I do my cam upgrade?
Modified by dat_flip at 8:04 PM 7/17/2004
Old Jul 17, 2004 | 10:46 AM
accorse07's Avatar
Default Re: which injectors? (dat_flip)
just go with 290's...you may want a fuel pump too...
Old Jul 17, 2004 | 11:05 AM
dat_flip's Avatar
Default Re: which injectors? (accorse07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 &raquo;</TD></TR><TR><TD CLASS="quote">just go with 290's...you may want a fuel pump too...</TD></TR></TABLE>
Oh yeah I have that stuff too... I for got to put that up there
Old Jul 17, 2004 | 11:20 AM
riceball777's Avatar
stock injectors will be fine for that set up
Old Jul 17, 2004 | 11:22 AM
siR cr-x's Avatar
i would go with 290 so you don't have to chane them later sould work with no problem
Old Jul 20, 2004 | 03:49 AM
93H22ACX's Avatar
Default Re: which injectors? (siR cr-x)
just get some 97-01 Prelude Inectors
Old Jul 20, 2004 | 08:34 AM
f@sth@tch89's Avatar
Default Re: (Rob Deal)
since you have the 290cc's i would use those. Either one will work fine. I would upgrade the TB or bore it out. Good luck.
negusjuda
Feb 6, 2010 01:42 PM
SiR Inspired ED7
15
Jul 29, 2007 02:19 AM
Ruben19
Jan 27, 2006 12:48 PM
hybridEj6
Jan 31, 2005 01:42 PM
jeremy.
Sep 29, 2003 05:35 PM
