I cant start my car my battery is dead
Old Jul 17, 2004 | 09:53 AM
sky88's Avatar
Default I cant start my car my battery is dead
This happens to me continuosly for a week i have been changing nearly 5 battery, my alternator is totally fine what is wrong with my car.THe battery just die off ,what is the possible reasons?
Old Jul 17, 2004 | 10:06 AM
HXMan's Avatar
Default Re: I cant start my car my battery is dead (sky88)
You might want to post this in the right forum. Like Tech or something.
Old Jul 17, 2004 | 10:11 AM
vtecn8ive's Avatar
Default Re: I cant start my car my battery is dead (HXMan)
Yeah why did you post it here?
Probably an improper ground.
Old Jul 17, 2004 | 10:30 AM
MachAF's Avatar
get a new battery.. that will solve your problem.
Old Jul 17, 2004 | 11:01 AM
sky88's Avatar
Default Re: I cant start my car my battery is dead (vtecn8ive)
ALL my bettery is brand new,and what u mean by in proper ground?
Old Jul 17, 2004 | 11:02 AM
nojoke's Avatar
Default Re: I cant start my car my battery is dead (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">get a new battery.. that will solve your problem.</TD></TR></TABLE>
He said he changed the battery 5 times.
How do you know your alternator is perfectly fine? Check that again, or maybe your voltage regulator
Old Jul 17, 2004 | 11:05 AM
vtecn8ive's Avatar
Default Re: I cant start my car my battery is dead (nojoke)
Take out a voltmeter and get to work.
Old Jul 19, 2004 | 07:01 AM
sky88's Avatar
i check my alternator through microtech and send to battery shop to check as well they told me something is using the battery even when the engine is not running please help me any other possible reasons ? can it be my earth wire
Old Jul 19, 2004 | 08:13 AM
OTT's Avatar
OTT
If yur alternatr is fine and you know the battery(s) are are fine then as you said you most likely have somthing draining the power
To my knowledge the most common two things to drain power from a car will be an aftermarket amplifier or a car alarm with a backup battery that constantly charges itself.
hope that Helps.
Old Jul 20, 2004 | 08:36 AM
sky88's Avatar
Default Re: (OTT)
how do u know wheter it is the amplifier? How to do a quick check?
Old Jul 20, 2004 | 08:57 AM
LudeyKrus's Avatar
Disconnect the amp and see if it still has the problem.
I would have said a bad ground of the alternator, but if you have an amp wired incorrectly, it will cause the same thing.
young3bro
23
Dec 6, 2007 07:48 AM
TomSwift
Oct 16, 2006 02:07 PM
tigueremalo
May 23, 2006 10:55 AM
dude wheres my car
Audio / Security / Video
Jul 16, 2004 07:16 AM
GroundZer0 336
Mar 6, 2004 05:55 PM
