OEM ZC Head Handle 13psi?
Old Jul 17, 2004 | 12:30 AM
Full Race A6's Avatar
Default OEM ZC Head Handle 13psi?
Dont know much about what a head can take. But my friends certain he can run 13-15psi tuned on his dual cam zc. Anyone know if there are any problem with oem **** at those levels. I dunno just have some questions
May boost my soch down the road. Head work other than a cam might not be in the budget
Old Jul 17, 2004 | 04:46 AM
90crxzc's Avatar
anything over 12 psi with the stock sleeves your pushing your luck
Old Jul 17, 2004 | 11:25 AM
Default Re: (90crxzc)
lol What are sleeves?
Never really learned anything past springs/valves/retainers/cam
Old Jul 17, 2004 | 04:14 PM
hahagasdcrx's Avatar
Default Re: (W O T)
Sleeves, as in the sleeves in your block. I dont see why the head wouldn't, your head gasket, rods and/or sleeves might not hold up to it.
Old Jul 17, 2004 | 04:26 PM
mr_valentino20032000's Avatar
Default Re: (hahagasdcrx)
I sent you an IM but for the point of people reading this post i'd highly recomend checking out http://www.homemadeturbo.com , they told about block posting and how that will last up to 25 PSI. As for the head i don't see why not but as for the stock rods...i have always heard after 6-8 PSI you need to replace them with stronger ones.
Good luck
Old Jul 17, 2004 | 04:43 PM
Default Re: (mr_valentino20032000)
Ya I didnt know if oem valves would burn or not be able to keep up or whatever
Old Jul 17, 2004 | 06:03 PM
HondaKPX's Avatar
Default Re: (W O T)
my dads a machienest and he did some work on a head one time that a guy wanted to run 35 psi on. ill tal to him later on and ask what he did exactly but i guess it worked the guy loves him. always wants him to do more.
Old Jul 18, 2004 | 08:05 PM
Default Re: (HondaKPX)
very interested
Old Jul 18, 2004 | 08:21 PM
MooreBoost's Avatar
Default Re: (W O T)
Its really all about the tuning. If its tuned correctly, then you should be able to pull it off, but it will be on the edge either way.
Old Jul 18, 2004 | 09:18 PM
CRXRageD's Avatar
Default Re: OEM ZC Head Handle 13psi? (W O T)
The weakest link in a stock d16 are the rods. I think that even with good tuning, your rods will give way and put a hole in your block. You can run about 200 whp safely before requiring upgrading internals. Still at that power I would invest in some internals. You can post the block or get new sleeves.
Old Jul 19, 2004 | 04:34 PM
ExplicitSpeed's Avatar
rods, rod bolts, sleeves, rings, pistons............................
Old Jul 19, 2004 | 10:06 PM
Default Re: OEM ZC Head Handle 13psi? (ExplicitSpeed)
**** sleeves
Old Jul 19, 2004 | 10:53 PM
HondaKPX's Avatar
whats wrong with sleeves? just curiouse
Old Jul 19, 2004 | 10:57 PM
ImportHatch's Avatar
Default Re: OEM ZC Head Handle 13psi? (HondaKPX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKPX &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with sleeves? just curiouse</TD></TR></TABLE>
Sounds like you should really do some searching.
Yager-
Old Jul 19, 2004 | 11:26 PM
Default Re: OEM ZC Head Handle 13psi? (ImportHatch)
Yeah Im prety ******* sure the sleeves wount be jsut fine and not worth the massive cost + large install fee that comes with them
May be building this motor for nitrous. I dunno
More help the better, also if anyone knows of anyone selling a head. PM
hondacrxturboSi
Apr 28, 2007 02:00 PM
hondacrxturboSi
14
Apr 25, 2007 03:45 PM
Burning2nd
Aug 30, 2006 08:59 AM
mymeatb18"
Jun 17, 2006 11:33 AM
