Turn off Maintenance Required Light on a 99 Si?
I had seen a pic of what your looking for on here. I tried searching for it but came up with nothing. Sorry. But I'm pretty sure that's where it is.
I know its not your car, but on my sister's '01 civic. I had to depress the reset button in the cluster and then with the key in the ignition turn it to the "Accessories On" position and leave it there for 5 or 10 seconds. It was the same on my tsx too. Hope this is helpful.
on your cluster, there should be a slit w/ a lever sticking out flush w/ the clear plastic. push that in with your key and it will reset. i had the same issue, and i have a 00 Si cluster.
EDIT: https://honda-tech.com/zerothread?id=850410 that's for an old thread that i made about this same issue.
sshaikh01
10
Apr 16, 2005 11:44 AM
