Randoms Weights (clutch, tires)
Old Jul 16, 2004 | 03:08 PM
98ITR#0020's Avatar
Default Randoms Weights (clutch, tires)
So when I put my new clutch/flywheel in I weighed the old stuff and the new. The old PP/clutch/flywheels weighed in around 28lbs. The new stuff weighed @ 22.5. This was a ACT HDSS w/the prolite flywheel. The used disc was almost 2lbs lighter than the new one because it was pretty gone.
I recently also got new Azenis mounted, and The new tires weighed in at a hefty 24lbs(around). I kept one of the bald tires and it was under 19lbs. I was pretty surprised that that much rubber comes off these things. On four bald tires you lose about 20lbs. Not bad
The bald tire is now swinging from a tree with my friends pit attached to it...Funny ****
Old Jul 16, 2004 | 03:27 PM
Opie's Avatar
Default Re: Randoms Weights (98ITR#0020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 &raquo;</TD></TR><TR><TD CLASS="quote">
The bald tire is now swinging from a tree in my backyard </TD></TR></TABLE>
You redneck
Old Jul 16, 2004 | 04:07 PM
743power's Avatar
Default Re: Randoms Weights (opie)
Were your old tires azenis too? I dont see how you can lose 5lbs of tread, unless there was no tread left.
If the old tires were not azenis, than the weight difference is because azenis are notoriously heavy.
Old Jul 16, 2004 | 04:34 PM
98ITR#0020's Avatar
Default Re: Randoms Weights (743power)
Yep, they were Azenis. Of course they were bald, thats why I got new tires
Still workin Opie?
Bald Azenis
Modified by 98ITR#0020 at 6:02 PM 7/16/2004
Old Jul 16, 2004 | 05:00 PM
743power's Avatar
Old Jul 16, 2004 | 07:50 PM
Stinkycheezmonky's Avatar
Suspetise...
There's still some life left in those
Old Jul 17, 2004 | 06:56 AM
98ITR#0020's Avatar
Default Re: Randoms Weights (sscguy)
Thats what I was thinking, but Azenis get loud as hell when there bald. Especially when you have a *slight* camber problem ..
Old Jul 17, 2004 | 07:33 AM
Suspetise...
They look more like they were overinflated, as there's still some tread on each edge.
Old Jul 17, 2004 | 09:27 AM
Rene M's Avatar
(-) camber does that... When you get to 80% then flip them... Left front to the right front and so on... we do it all the time on auto x tires..
Evolution-93-Ex
Feb 17, 2008 09:34 AM
Tippyman
Jun 16, 2006 08:51 PM
flashmang
Mar 18, 2005 04:51 PM
importtuner
Jul 23, 2004 09:21 AM
tallblondkid
Aug 5, 2003 03:03 PM
