Type-R Alignment results, good, bad, ugly...?
2001 Type-R, lots of miles, ~6-8 track days per year, 6 autocrosses, and ~25,000 mountain road miles. Car weight is ~2,800 lbs with me in it and a half tank of gas, which is where it was when I had the alignment.
Austin
[Front
----------Left-------Right
Caster--+1.2*----+0.6*
Camber-<u>-</u>2.2*---<u>-</u>1.9*
Toe------0.0-------0.0---
Rear
Camber-<u>-</u>1.7*----<u>-</u>1.9*
Toe------0.10*-----0.10*---
Thrust Angle 0.0
Modified by Austin at 1:39 PM 7/16/2004
Austin
[Front
Rear
Thrust Angle 0.0
From: living too close to Karl, everythings busted, nc
it may pull some to right with lower camber/caster. should be a very stable car with the fair amount of toe in in the rear
Austin, that alignment was done according to stock ITR specs, right?
For track duty ... don't people often recomend a tad of toe (1/16 or so) up front, and 0 toe in the back?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">For track duty ... don't people often recomend a tad of toe (1/16 or so) up front, and 0 toe in the back?</TD></TR></TABLE>
are you saying to toe it in or out. toe out will make it turn in better, but slow it on the straights. toe in will make it understeer more, but will be more stable
Andrew 825SM
Aug 15, 2003 03:16 AM
