b18c1 into 90 hatch axle question
so like the title says i have installed a b18c1 engine into ,my 1990 civic si hatch...i ahve also purchased 90-93 integra axles i have my stock axles and axles from a 94 gsr...what combo do i use for this swap...keep in mind i am using the hydro tranny from the gsr...thanks for any help
use the gsr axles since you have the gsr int shaft. the passenger teg axles are all the same length but the drivers sides are different cause of the spline into the int axle shaft.
ok thanks for the info guys but one of the main problems i am having is that the axle is too big to fit into the hub...i have an si(1990) so shouldnt they fit fine?
im gonna look into that to see if thats the problem(the car is far away and i have no ride, other ride) does anybody else have any help they could give me just incase this isnt the problem?
HamiltonRex
Feb 22, 2006 03:58 AM
