need help from wiring guru - k20a EK swap w/rsx cluster
Old Jul 16, 2004 | 10:22 AM
6SPD_EK's Avatar
Default need help from wiring guru - k20a EK swap w/rsx cluster
I am looking for someone that can either modify a hasport K20 harness for EK or make a custom harness for k20a EK that will allow me to use a RSX-S cluster (100% functional) or even just shed some more light on the subject . I know this is complex & already asked brian G but its too much for hasport to do a "one-off" harness
I am willing to supply
RSX-S interior harness
RSX-S multiplexor / under the dash fuse box
RSX-S engine harness*
RSX-S charging harness*
2000 Dx engine harness*
2000 Dx interior harness
I have a RSX-S cluster with the plugs (wires cut)
* may be substituted with custom hasport EK/K20a harness
here is an informative thread on the complications of the RSX-S cluster in older honda's... https://honda-tech.com/zerothread?id=828752
but one area will be easier since this time there will be a k20a swap to go with the cluster
any help or anyone that can suggest who i can talk to who might be able to this - would be greatly appreciated.
one possibility would be to run (convert to) everything off the RSX interior harness ???
Modified by adirondackR at 2:46 PM 7/16/2004
Modified by adirondackR at 4:13 PM 7/26/2004
Old Jul 16, 2004 | 10:57 AM
Nikos's Avatar
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (adirondackR)
I am not a wiring guru. If you really want to do this, why not just use a complete RSX dash board and hook everything up to the k motor via ecu?
Old Jul 16, 2004 | 11:00 AM
6SPD_EK's Avatar
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (Nikos)
I'd like to stick w/EK dash....I don't really like the RSX-S dash - just the cluster I know it can be done in a eg...thanks tho
Time for me to bust out the interior harness diagrams for the RSX-S and my dx hatch from my helms manuals...I don't know squat about wiring tho
Old Jul 16, 2004 | 11:01 AM
Nikos's Avatar
Old Jul 17, 2004 | 08:32 AM
07's Avatar
07
that thing was on ebay awhile ago.
Old Jul 17, 2004 | 06:38 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (Calculator)
Damn, pictures of that car have been all over H-T.
Old Jul 18, 2004 | 12:36 AM
eg_type_r93's Avatar
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (rochesterricer)
i think its butt
Old Jul 19, 2004 | 03:57 AM
6SPD_EK's Avatar
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (eg_type_r93)
I did not create this thread so others could give me their opinion on the RSX dash in another car...I don't want the dash, just the cluster - thanks. bump for any more info. - thanks - Greg
Old Aug 9, 2004 | 05:40 AM
6SPD_EK's Avatar
bump - for someone who can do this for me
Old Aug 9, 2004 | 01:19 PM
GiT LaO'd's Avatar
do it yourself and learn something new...
Old Aug 12, 2004 | 04:16 AM
6SPD_EK's Avatar
Default Re: (jaybee)
thanks for the vote of confidence - but after thoroughly looking into this - i found this is NOT something for me to tackle (& F up $1000+ worth of harnesses )
bump - I really need to find someone to do this for me.....
Old Aug 14, 2004 | 05:46 AM
hybrid racing's Avatar
Default Re: (adirondackR)
PM sent
Old Aug 14, 2004 | 09:00 PM
blackdelslo's Avatar
Default Re: (hybrid racing)
hmmm i wonder if rsx dash will work in del sol. now that would be sexy.
Old Aug 23, 2004 | 08:50 PM
KustomCrx's Avatar
Default Re: (delLudeVTEC)
hey adirondackR would you be willing to sell the harness? or the plug for the cluster? I'm sure I can make it work.
Old Aug 23, 2004 | 08:58 PM
PHiZ's Avatar
Default Re: (KustomCrx)
Man, too bad I'm about to start school, I'm qualified to do this, I'm semi-local, but i'm not going to have the time.
I'm finishing up an H22 into a 6th gen accord at the moment.
-PHiZ
Old Aug 24, 2004 | 04:03 AM
6SPD_EK's Avatar
sorry - but its not f/s...you'll need the fuse box/multiplexor to get the gauge cluster to work properly (aside from the RSX interior harness)
anyways Hybrid-Racing is going to make a custom harness for me...I just need to source 99-00 DX engine & firewall (& maybe floor harness too - not sure if I need it or not, but I am going to supply it just in case). it won't be for a while tho - jdm k20a swap is being installed this winter
Should be interesting tho - b/c it looks like I may be able to use the RSX-S engine harness almost completely unmodified - coupled with the RSX-S interior harness modified to plug into the dash. this would mean I would get to use all the OEM RSX-S relays - instead of hardwiring them or wiring them into the EK main relay
Modified by adirondackR at 1:13 PM 8/24/2004
Old Aug 24, 2004 | 08:11 AM
KustomCrx's Avatar
Why do you need the floor harness? Hey I cant Im, but I have AIM screen name is CrxPlatinum
Old Aug 24, 2004 | 09:39 PM
KustomCrx's Avatar
Hey, if you want the floor harness from rsx I can sell it to you. The only thing thats missing is a factory amp wire, which I'm sure you dont need. I'm really sure this harness would make your car more complete so your gauges would get more signals, like the fuel pump, and ext... These sell for $375 or something like that, I'll sell it less than half, because I want to see the pics of your gauges, and then I'll know I had a little to do with them.
Old Aug 25, 2004 | 07:42 AM
KustomCrx's Avatar
Do you have the turn signal and head lights switch?
Old Aug 25, 2004 | 07:57 AM
6SPD_EK's Avatar
Default Re: need help from wiring guru - k20a EK swap w/rsx cluster (KustomCrx)
no - i don't have the turn signal & headlights switch... hybrid racing is going to modify the rsx interior harness to plug into the EK dash (including the headlights & turn signals). Thats why I am suppling the rsx-s interior harness, rsx-s engine harness, rsx-s multiplexor/fusebox & the EK interior harnesses...in return I will get a modified RSX-S engine harness (longer battery lines) and a modified RSX-S interior harness with custom wiring for plugs (oem ek) for the ek dash
edit - sorry I don't need the rsx-s floor harness either - there is no reason for me to get the rsx-s floor harness...oem EK floor harness will plug into modified RSX-S interior harness
vroomvroomjdm24
May 21, 2015 07:00 PM
Dontoh
Jun 29, 2010 04:17 PM
6SPD_EK
Nov 2, 2004 11:34 AM
