b16 problems
Old Jul 16, 2004 | 08:54 AM
j_max420's Avatar
Default b16 problems
i put a b16a with 30,000 miles in my 91 hatch, now the car runs great, but vtech wont kick in when engine is cold, is this normal. and also i know the b16 has a reputation with head gasket failure, with oil leaking externally, but with 30k
Old Jul 16, 2004 | 08:58 AM
mmuller's Avatar
Mad Scientist
Default Re: b16 problems (j_max420)
the stock ecu wont allow vtec to quick in untill the temp. is over 150degrees , i believe.
b16 are known for hg. failures? not really
Sack Master's Avatar
Why are you getting on it when the engine is cold anyways? But to answer your question. Most VTEC ecus won't let VTEC engage while its cold.
Old Jul 16, 2004 | 09:03 AM
j_max420's Avatar
Default Re: b16 problems (mmuller)
actually they are known for head gasket failure, atleast in my shop i can think of atleast 4 times we have replaced headgaskets in b16's
Old Jul 16, 2004 | 09:09 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_max420 &raquo;</TD></TR><TR><TD CLASS="quote">actually they are known for head gasket failure, atleast in my shop i can think of atleast 4 times we have replaced headgaskets in b16's</TD></TR></TABLE>
mmk, if you say so
care to explain why?
Old Jul 16, 2004 | 09:17 AM
j_max420's Avatar
i honestly dont know why, but the failure they have is not coolant internally, it is always externally, if you have ever seen a failed honda head gasket it always leaking out of the front corner of the engine by the distributer. but in my case it is oil. i have been at this shop for 2 years, and we see this problem all the time
Old Jul 16, 2004 | 11:02 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_max420 &raquo;</TD></TR><TR><TD CLASS="quote">i honestly dont know why, but the failure they have is not coolant internally, it is always externally, if you have ever seen a failed honda head gasket it always leaking out of the front corner of the engine by the distributer. but in my case it is oil. i have been at this shop for 2 years, and we see this problem all the time</TD></TR></TABLE>
you sure yer not mixing up a leaky cam seal or leaky vtec solenoid seal? cuz that's normally wut the culprit is when there's oil around the area you speak of...
curious too, what year are the four B16 engines that you changed the h/g's on? 89-91? 92+?
hondaex99
Mar 4, 2010 06:22 AM
eda6
Nov 23, 2004 12:28 PM
sykotik sol
Nov 17, 2004 03:08 PM
grenthang
Feb 4, 2004 09:29 PM
grenthang
Feb 4, 2004 07:15 PM
