Uberdata ---> usb female adapter port
Old Jul 16, 2004 | 07:34 AM
redlinetuning's Avatar
Default Uberdata ---> usb female adapter port
Ok, so i've read articles about the Nokia USB adapter, but I have another idea.
I have a female USB adapter port left over from my pc. I figured this might be another solution. I want to be able to connect the 4 wires adapter to the ECU (CN2) connectors and mount the USB adapter plate to the ECU for ease. Then just plug a usb cable to the ecu and to the PC.
Here is the wiring schema for the USB adapter port:
red (+5v)
white (data-) Rx?
green (data+) Tx?
black (ground)
black (ground, shell) possibly to ecu housing?
ECU CN2:
#1 = Ground
#2 = Tx
#3 = +5v
#4 = Rx
#5 = N/A
So, in theory, I should be able to connect the four, mount the adapter plate to the ECU, and use a cable, right? Suggestions? ??
Old Jul 16, 2004 | 07:48 AM
Charlie Moua's Avatar
Default Re: Uberdata ---> usb female adapter port (redlinetuning)
bump.... where is the uberdata gurus?
Old Jul 16, 2004 | 07:51 AM
showtymers619's Avatar
* B A N N E D *
Default Re: Uberdata ---> usb female adapter port (Charlie Moua)
in theory yes but to only find out.. is trial and error
Old Jul 16, 2004 | 07:55 AM
Default Re: Uberdata ---> usb female adapter port (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 &raquo;</TD></TR><TR><TD CLASS="quote">in theory yes but to only find out.. is trial and error</TD></TR></TABLE>
I was afraid you'd say that.. I kinda figured. but I wanted to make sure before i try anything.. i have a spare P05 ecu i could test it on.. i guess we'll see. any other suggestions?
Old Jul 16, 2004 | 08:09 AM
dsadas89das78934's Avatar
i dont see why it couldnt work... so long as you get all the connections correct.
Old Jul 16, 2004 | 08:21 AM
lohatch's Avatar
hit up kevin. i am still an uberdata novice
Old Jul 16, 2004 | 08:37 AM
Default Re: Uberdata ---> usb female adapter port (lohatch)
yeah.. Kevin's out of town for a week though..
Old Jul 16, 2004 | 12:46 PM
shermanyang's Avatar
the only way to find out for sure is trial an error bro. if you've got a spare ecu...there won't be any harm done...don't worry, even if there is, i can fix it for ya. it sounds like it'll work...but sometimes things don't happen the way you would expect them too.
Old Jul 16, 2004 | 03:52 PM
BigMoose's Avatar
Default Re: Uberdata ---> usb female adapter port (shermanyang)
You might have better luck by going to the uberdata forum at
http://www.ecimulti.org/uberdata/forum/
Old Jul 16, 2004 | 04:04 PM
Jim Truett's Avatar
Default Re: Uberdata ---> usb female adapter port (BigMoose)
You still need the Nokia cable to convert the TTL signal from the ECU to a serial format to be compatible with the PC.
Old Jul 16, 2004 | 05:53 PM
X2BOARD's Avatar
So (if it works) would allow to reburn a chip directly right ? (uberdata pre-rookie...lol)
Old Jul 16, 2004 | 09:22 PM
Jim Truett's Avatar
Default Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">So (if it works) would allow to reburn a chip directly right ? (uberdata pre-rookie...lol)</TD></TR></TABLE>
No. You would need to have a NVSRAM chip and the associated hardware set up in the ECU to allow RTP. Start here: http://www.pgmfi.org
Old Jul 17, 2004 | 09:36 AM
PHiZ's Avatar
Default Re: Uberdata ---> usb female adapter port (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">You still need the Nokia cable to convert the TTL signal from the ECU to a serial format to be compatible with the PC.</TD></TR></TABLE>
You might be able to do it in software, I'm not sure what the USB hardware spec defines...
-PHiZ
Old Jul 19, 2004 | 06:49 AM
Default Re: (Jim Truett)
No. You would need to have a NVSRAM chip and the associated hardware set up in the ECU to allow RTP. Start here: http://www.pgmfi.org</TD></TR></TABLE>
Correct, this will not allow me to burn the chip directly.. like Jim said..
I'm just trying to get a cheaper work-around since I have all this computer stuff laying around at home collecting dust..
EG6 Love
Engine Management and Tuning
16
Oct 9, 2011 09:13 AM
lsjon
May 30, 2008 08:41 AM
exownzu
Nov 30, 2006 03:21 PM
red97EX
Sep 20, 2005 10:42 AM
mockujin
Nov 17, 2002 06:06 AM
