No Oil Pressure Problems
Old Jul 16, 2004 | 05:46 AM
0evilEMPIRE0's Avatar
Default No Oil Pressure Problems
hello there and thank you -- i just have a quick question for everyone? after a long time of not havin all the money and bs, i got my motor built and installed in my hatch. i went to do the new engine brake-in, hooked-up my oil pressure gauge, and with no spark plugs, i cranked her over. come to find out that i have no oil pressure! i installed a new type r oil pump that i bought from the dealership, along with new ACL bearings i got from Earl. i was wondering if there is anything else i could do or check before i start taking things apart?? i don't see why a brand new oil pump wouldn't work? if anyone could help me out in anyway that would be sweet!!! thanks
Old Jul 16, 2004 | 06:44 AM
Default Re: No Oil Pressure Problems (0evilEMPIRE0)
anyone??
Old Jul 16, 2004 | 08:05 AM
noone?
Old Jul 16, 2004 | 08:08 AM
mmuller's Avatar
Mad Scientist
so what you crank the motor over and it wont build pressure?
Old Jul 16, 2004 | 08:17 AM
Default Re: No Oil Pressure Problems (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">so what you crank the motor over and it wont build pressure?</TD></TR></TABLE>
yep! i installed a brand new type r oil pump but i don't see why that would be the problem? can anyone help?
Old Jul 16, 2004 | 08:50 AM
turbohondask's Avatar
did you do install it right and is there oil in the pan?
Did you put the pick up tube back also?
Old Jul 16, 2004 | 10:03 AM
Default Re: No Oil Pressure Problems (turbohondask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohondask &raquo;</TD></TR><TR><TD CLASS="quote">did you do install it right and is there oil in the pan?
Did you put the pick up tube back also?</TD></TR></TABLE>
how can u install it wrong?? its notched for the crank, correct? theres plenty of oil, thats what the stick says! and the pick up was installed with a clean screen.
anyone else?
Old Jul 16, 2004 | 10:33 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0evilEMPIRE0 &raquo;</TD></TR><TR><TD CLASS="quote">
anyone else? </TD></TR></TABLE>
for how long did you crank it? it takes a while before pressure starts building
Old Jul 16, 2004 | 11:52 AM
for how long did you crank it? it takes a while before pressure starts building</TD></TR></TABLE>
i did it twice for 20secs each. should i crank it longer?
Old Jul 16, 2004 | 12:04 PM
H2B just chillin's Avatar
WERE WAS THE OIL LINE FROM THE GAUGE HOOKED UP TO BLOCK OR HEAD ECT.
IF IT WAS HOOKED UP TO THE HEAD IT WILL ONLY READ AT HIGH RPM OR VTEC MODE I HAD THE SAME PROBLEM HAD IT HOOKED UP ON THE HEAD AND THOUGHT MY PUMP WENT BAD
Old Jul 16, 2004 | 01:13 PM
Default Re: No Oil Pressure Problems (20LvtecTURBOeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20LvtecTURBOeg &raquo;</TD></TR><TR><TD CLASS="quote">WERE WAS THE OIL LINE FROM THE GAUGE HOOKED UP TO BLOCK OR HEAD ECT.
IF IT WAS HOOKED UP TO THE HEAD IT WILL ONLY READ AT HIGH RPM OR VTEC MODE I HAD THE SAME PROBLEM HAD IT HOOKED UP ON THE HEAD AND THOUGHT MY PUMP WENT BAD</TD></TR></TABLE>
i hooked up the tester to the back of the block where the oil press. sensor is located - anyone?
Old Jul 16, 2004 | 02:25 PM
dclsvtec's Avatar
so when the engine its self is on and running, and you can rev it and all that shyt, the guage still says 0psi??
Old Jul 16, 2004 | 03:22 PM
Dan GSR's Avatar
Default Re: No Oil Pressure Problems (dclsvtec)
crank it for a while longer
did u put a new o ring when u installed the oil pump?
Old Jul 16, 2004 | 03:26 PM
spaceman's Avatar
did you prime the oil pump before you installed it?..what motor do you have?..i would also put more oil in,go past the max mark..that will help get it going..
Old Jul 16, 2004 | 03:29 PM
krazie1's Avatar
BANNED
Default Re: No Oil Pressure Problems (Dan GSR)
[QUOTE=Dan GSR]crank it for a while longer
QUOTE]
now there is a good answer
Old Jul 16, 2004 | 05:09 PM
dclsvtec's Avatar
Default Re: No Oil Pressure Problems (krazie1)
my oil pressure guage only reads when the car is on. when im trying to start the engine it will just read 0 till the car actualy starts when it runs it will be like 50 when its warming up. and when its warmed up its like at 5 to 10 psi imlike at 80 in vtec
Old Jul 16, 2004 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dclsvtec &raquo;</TD></TR><TR><TD CLASS="quote">so when the engine its self is on and running, and you can rev it and all that shyt, the guage still says 0psi?? </TD></TR></TABLE>
nada, havn't gottin that far. tryin to build oil pressure before i start the engine.
Old Jul 16, 2004 | 05:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">crank it for a while longer
did u put a new o ring when u installed the oil pump?</TD></TR></TABLE>
yes new o-ring and i primed it with some 10w30 before install
Old Jul 16, 2004 | 05:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dclsvtec &raquo;</TD></TR><TR><TD CLASS="quote">my oil pressure guage only reads when the car is on. when im trying to start the engine it will just read 0 till the car actualy starts when it runs it will be like 50 when its warming up. and when its warmed up its like at 5 to 10 psi imlike at 80 in vtec
im using a brand new snap-on oil pressure tester cause no one around here had one for sale, but it should read around 10psi during cranking right?? i'll try with a little more oil and crank it some more.
anyone else??
thanks everyone for the help
Old Jul 16, 2004 | 06:33 PM
Dan GSR's Avatar
you may/may not be able to get a readable pressure from just cranking the motor with the starter
Old Jul 16, 2004 | 06:42 PM
dclsvtec's Avatar
i agree with dan, cause the engine cranks prety slow when your just starting it
Old Jul 17, 2004 | 11:33 AM
anything else?
Old Jul 17, 2004 | 02:50 PM
you might wanna check to see if the gauge is any good iwould just hook up a screw on type gauge like a fuel psi gauge no wiring no tubes and screw it on the side of the head and rev it up NOTE: it only reads at high rpm's then youll know if theres oil pressure or not
Old Jul 17, 2004 | 02:54 PM
Dan GSR's Avatar
at idle
my autometer reads around 30psi
ilde is a lot more rpm than the starter alone can produce
al full throttle i get about 90psi
Old Jul 17, 2004 | 04:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0evilEMPIRE0 &raquo;</TD></TR><TR><TD CLASS="quote"> i cranked her over. come to find out that i have no oil pressure! </TD></TR></TABLE>
Try filling the oil filter with oil then cranking it. It can take a while sometimes but that usually helps.
