Best shift point?
Old Jul 16, 2004 | 01:27 AM
Schmitey's Avatar
Default Best shift point?
I was checking out the stats on my 96 Accord EX here http://www.streettuners.com/cu...ccord
I'm still a little confused on the diff. between torque and horsepower but where should I shift for fastest times 4.5k or 5.5? Yeah I should probably know the difference but I'm a nuts and bolts guy not the numbers brainy type. All I know is the higher the number the better, unless its your quarter mile time lol.
Old Jul 16, 2004 | 04:51 AM
Grodzman's Avatar
6000-6200 on the stock motor w/ a good I/H/E + testpipe/highflow cat. Stock you wanna shift at 6000 or even a little less.
It all depends on the modifications too, like if you have cams or something, it's a whole different story. So, what do you have under the hood?
Old Jul 16, 2004 | 05:15 AM
toxxin erik's Avatar
Default Re: Best shift point? (Schmitey)
also what motor do you have in ur car? stock singlecam vtec or perhaps an h22?
Old Jul 16, 2004 | 05:25 AM
Yodzilla's Avatar
Default Re: Best shift point? (toxxin erik)
This might not be true, but it seems like Accords prefer to be shifted at lower RPM's than a Civic V-Tec. I'd say shift at 5 to 5.5k.
Old Jul 16, 2004 | 07:49 PM
Schmitey's Avatar
Default Re: Best shift point? (Yodzilla)
Stock F22b1 still
Old Jul 16, 2004 | 07:54 PM
fw190bvi's Avatar
top power is at 5.5K....why would you ever want to go much past that.....your just wasting time while your flatlining your HP curve, and your torque hits the ****
Fastwhip
Feb 12, 2008 10:18 PM
JDM00SI
Apr 20, 2005 02:59 PM
DarKStaR5
Dec 7, 2004 05:47 PM
Austin
Sep 5, 2002 12:16 PM
REDMAN1322
Nov 7, 2001 06:00 AM
