Timing mark questions and what # do put the knob to on the timing gun
Old Jul 15, 2004 | 10:53 PM
racingant's Avatar
Default Timing mark questions and what # do put the **** to on the timing gun
I have a jdmd15b motor single vtec 1.5 what the timing mark for the motor
the other day about 1 month ago i changed y timing belt on my single vtec motor
and at that time it was still obd0 and now i did the 0bd0-0bd1 and from when i did that the timing is off i couldn't get it to line up with the middle msrk (the red mark) i can get it to line up with the tdc mark but not the red one for some reason and the dis is all the way to the fire wall and with it all the way to the fire wall it lines up in the middle of the tdc and the 3 marks and the ime gun is 16 is that right
Old Jul 16, 2004 | 05:19 AM
crx_88_si's Avatar
did u jump the service connector?
Old Jul 16, 2004 | 09:14 PM
racingant's Avatar
Default Re: (crx_88_si)
yes i jump the wire under the dash on thr driver side of the car
Old Jul 17, 2004 | 10:06 AM
jlicrx's Avatar
Default Re: Timing mark questions and what # do put the **** to on the timing gun (racingant)
if you are using timing light where you can set the light to 16 degrees and then check timing, you use the TDC mark - if you have a light that just flashes, you use the middle mark of the 3.
SilverGT
Jun 11, 2007 06:50 PM
roterx7
13
Mar 13, 2006 06:36 AM
importlegions
11
Apr 14, 2005 06:13 PM
seano
11
Oct 15, 2002 11:08 PM
