need help
Old Jul 15, 2004 | 09:43 PM
93slmdcvcsi's Avatar
Default need help
check this out people, i just got a 92 cx with a JDM b16A. The problem is that the car won't rev over 3500. The harness looks rough, and i am not sure what Dizzy to use for this vehicle. I am used to working on EF's, but for $2500 I couldn't turn it down. ya know. I would appreciate all the help that i can get! Thanx
Old Jul 16, 2004 | 06:26 AM
Default Re: need help (89cvchb)
someone has to know something.
bump
Old Jul 16, 2004 | 06:51 AM
delScho's Avatar
Sounds like it is in limp home mode. What codes are you getting? You should be getting at least one (but maybe more) with a jacked up harness. If you aren't getting any, I'd check to see that the MIL actually comes on and is connected properly. I've seen bad swaps where people just clipped the MIL lead from the ecu to hide their stupidity. You might have the same issue. Just a thought.
Old Jul 16, 2004 | 07:33 AM
Default Re: need help (delScho)
it is throwing a few codes, but i am not sure right at the moment but i will check and post them up. How can you get it out of limp mode?
Old Jul 16, 2004 | 07:58 AM
delScho's Avatar
Fix the source of the codes and reset the ecu. It's a programmed defense mechanism, you can't just make it go away.
Old Jul 17, 2004 | 05:14 AM
Is there a site where I can get a list of the OBD-1 Ecu Codes?
Old Jul 17, 2004 | 02:14 PM
Also another ? Can i use a complete 92-95 ex harness( motor + ecu ) on a cx chasis? Will it work with my b16?
Old Jul 17, 2004 | 04:31 PM
bump nees some help guys
Old Jul 17, 2004 | 11:53 PM
bump
Old Jul 18, 2004 | 05:36 AM
ShakesTheKlown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cvchb &raquo;</TD></TR><TR><TD CLASS="quote">Is there a site where I can get a list of the OBD-1 Ecu Codes?</TD></TR></TABLE>
Look at the very top of the EG+ Civic / Del Sol forum...
For ****'s sakes...
Old Jul 19, 2004 | 05:02 AM
Default Re: need help (ShakesTheKlown)
I hav still yet to get an answer about using a full EX harness on a CX chasis with a b16! Will that harness work and what will i hav to do to make it work?
hotxcivic92
15
Oct 2, 2007 09:41 AM
xXSilentScreamXx
10
Aug 7, 2007 03:09 AM
89eFRACER
12
Apr 13, 2006 09:21 PM
neEven
Jan 29, 2005 02:50 PM
simplestyles
Mar 4, 2004 01:54 PM
