b20 vtec building ?
Old Jul 15, 2004 | 09:39 PM
drunknbass's Avatar
Default b20 vtec building ?
just curious if anyone has ran higher compression with stock rods / bolts
im trying to cut as many corners as i can safely. im putting my motor together and will run it na for prob 3/4 months while i collect $ to sleeve it and basically fully build it.
but for the time being im not happy with the 9:5 or whatever compression its going to end up at. (b20b, b16 head)
so i was going to pick up some pistons and run like 12:1 compression,
i know is better to at least replace the rod bolts with arp.
but how safe is it to use the stocks.
and if i can get by using stock, i heard its not recommended to even reuse rod bolts.
Old Aug 24, 2004 | 07:57 AM
AllMoToRB18c's Avatar
Default Re: b20 vtec building ? (drunknbass)
arp rod bo9lts are only like $40 ....so u should just spend that lil money and buy them....stock rods should be ok for NA
excoupeb20jdm
Honda CR-V & Element
14
Jan 21, 2013 06:12 AM
Mad Cow Disease
May 22, 2004 09:10 PM
desert eagle
Apr 22, 2004 03:29 PM
PanamaVTI
Nov 9, 2003 10:31 PM
jcivicsib20
Mar 6, 2003 10:31 AM
