Blue smoke when taking off from a stop...why?
Old Jul 15, 2004 | 08:07 PM
allm0torGSR's Avatar
Default Blue smoke when taking off from a stop...why?
When I sit at a stop light for a minute or so, and then go I get a huge cloud of blue smoke behind me. What would cause this? My engine has 165,000 miles on it (1990 LX 4 door).
Old Jul 15, 2004 | 08:17 PM
T-Mo's Avatar
sound like burning oil. Piston rings, maybe????
Old Jul 15, 2004 | 08:40 PM
erebunicrx's Avatar
Default Re: (T-Mo)
do a comp test to see if its the rings or not. if you get ex,180, 140 ,181, 179 its the rings but if you get ex, 180,140, 135, 181 then its probally the head gasket. but it could be other things as well. like the valve seals.
Old Jul 15, 2004 | 09:17 PM
Default Re: (mrspeaker)
It does it pretty randomly. It doesn't do every time and it doesn't do it at startup, I suppose it could possibly be doing it while I'm driving, but I can't tell, because I'm driving!
Old Jul 15, 2004 | 09:44 PM
SECURITY's Avatar
Default Re: (USDMDC2NH)
My car used to do this when I first got it... I felt sorry for the people driving behind me! I took it to a mechanic and they replaced the oxygen sensor. The car was also running a DC 4-2-1 Header back then.
Old Jul 15, 2004 | 09:52 PM
lil big iron's Avatar
it the rings could be pvc.its not a head gasket and if it doesnt smoke when you first start it its probably not your valve seals.
Old Jul 16, 2004 | 07:15 AM
hndagirl's Avatar
Default Re: (big iron)
blue smoke= burning oil..possibly rings.
white smoke= coolent...possibly head gasket
get a compression test
Old Jul 16, 2004 | 08:01 AM
90crxzc's Avatar
your getting blow by, sounds like its time for a rebuild
Old Jul 16, 2004 | 08:02 AM
hndagirl's Avatar
Default Re: (90crxzc)
if its blow by, cant he just get new pistons and rings?
Old Jul 16, 2004 | 08:12 AM
hahagasdcrx's Avatar
Default Re: Blue smoke when taking off from a stop...why? (USDMDC2NH)
could be the rings, valve stem seals, and if you have poor performance a blown headgasket maybe. Get a compression check to narrow down what it could be.
Old Jul 16, 2004 | 08:24 AM
hndagirl's Avatar
Default Re: Blue smoke when taking off from a stop...why? (hahagasdcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">could be the rings, valve stem seals, and if you have poor performance a blown headgasket maybe. Get a compression check to narrow down what it could be.</TD></TR></TABLE>
it would be white smoke if it were a head gasket...hes burning a hell of a lot of oil if its dark blue smoke
Old Jul 16, 2004 | 06:59 PM
Default Re: (oh_crx)
My O2 sensor is brand new, I changed it about a month ago. I was getting a CEL/code 2 since I bought the car in April, I found out that a code 2 was the O2 sensor on this site by you fine folks. I replaced it and no more code 2.
I was also getting a bad distributor code, I took it back to the deaer to get that and the O2 replaced under warranty. They replaced the dizzy, but not the O2 like they said they had, liars!
Hmmm...all these sound like pricy fixes, especially for a little pissant 1.5 liter engine with 92HP which has apparently had the **** kicked out of it before it landed in my hands (this car was riced OUT when I bought it, first clue, right?). I think its time for a upgrade! I can get a ZC with 35-75K on it installed for $1400, good price?
Modified by USDMDC2NH at 4:33 AM 7/17/2004
Old Jul 16, 2004 | 07:14 PM
vtecn8ive's Avatar
Default Re: Blue smoke when taking off from a stop...why? (black89crxsi)
I'm saying valve seals. but only if it happens also when you start it up.
Old Jul 16, 2004 | 10:30 PM
Default Re: Blue smoke when taking off from a stop...why? (vtecn8ive)
he said it doesnt smoke when he first starts it up so i dont think its the valve seals.i think its the rings.why dont you just get a jdm b16a and **** it
Old Jul 17, 2004 | 03:01 AM
vtecn8ive's Avatar
Default Re: Blue smoke when taking off from a stop...why? (big iron)
oops didn't see that. Thanks.
Old Jul 27, 2004 | 10:08 PM
figured out whats wrong with it yet
LaOXXKIDD
Aug 15, 2009 12:05 PM
lilboxx
May 12, 2009 09:37 PM
KevinSmith88
Feb 23, 2009 04:20 PM
90datech
May 13, 2008 07:10 AM
codyb13
Jun 16, 2005 08:47 AM
