Which clutch for JDM YS1 cable trans?
Do I get the 92-93 GSR clutch or the 94-01 Integra clutch. I was told the 94-01 but I thought you get the clutch to match the year of the car the trans came from? This is from a XSi btw. Thanks
s1 / j1 / y1 = small trannie shaft 90-91 clutch
ys1 b16 trannie = big shaft 92-01 clutch
the only difference between cable and hydro is the thro out bearing
so you can use a clutch and pressure plate for a 92-01 teg but you must use a cable 90-93 throw out bearing
Ahhh ok. So I'm better off buying a kit made for a 92-93 GSR then since the TO bearing will fit as well as the clutch assembly? Thanks guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">s1 / j1 / y1 = small trannie shaft 90-91 clutch
Correct, but just to clarify, the YS1 (short geared) came on the B17 equipped 92 and 93 GSR. The YS1 (long geared) came on all other 92-93 5 spd INtegras.
StillenMaxSE99
16
Sep 29, 2008 09:52 PM
Suzukii
Jun 25, 2008 08:36 PM
Cyber ITR
Nov 1, 2003 12:56 PM
Cyber ITR
Nov 1, 2003 05:41 AM
