HHHHHHHHHEEEELLLPPPP!! Engine Shakes when I hit 65mph and above!! HEEELLLLPPPP!!!
Old Jul 15, 2004 | 04:47 PM
aldosound's Avatar
Default HHHHHHHHHEEEELLLPPPP!! Engine Shakes when I hit 65mph and above!! HEEELLLLPPPP!!!
This just started happening a week ago. I'm going 65 and all of a sudden my engine starts shaking as if its having trouble accelerating. i'm able to accelerate faster but as im going faster, my car starts shaking even more .. i dont know why this is happening. i swapped out my engine for a brand new one exactly a year ago. does anyone know why this is happening?? HHHEEELLPPP PLLLEEAAASSSEE!!!
Old Jul 15, 2004 | 04:54 PM
madd's Avatar
Default Re: HHHHHHHHHEEEELLLPPPP!! Engine Shakes when I hit 65mph and above!! HEEELLLLPPPP!!! (aldosound)
not to point out the obvious, but HOW IN GOD'S GOOD NAME CAN PEOPLE HELP YOU WIHTOUT MORE INFORMATION! when you ask a question is is best asked in such a way that you also provide information. such as: what year, type of motor, transmission, etc...
Old Jul 15, 2004 | 05:06 PM
jwogen1's Avatar
what regular maintenance have you preformed on the engine since it was dropped in
H22SiRaccord's Avatar
sure it is your motor and not your susp.....shaking like bitch.....
Old Jul 15, 2004 | 05:11 PM
madd's Avatar
Default Re: (H22SiRaccord)
mine did that at around 55, but it was due to my horribly unbalanced tires...but after speeding up it was better.
i would look into doing an alignment and balance/rotate tires, and suspension, before you start looking into the engine.
Old Jul 15, 2004 | 05:14 PM
Master23's Avatar
Definitly check out the suspension alignment and the tires. It happend to me before and it turned out to be a worn out rear tire.
Old Jul 15, 2004 | 06:10 PM
FatJoe's Avatar
Default Re: (madd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madd &raquo;</TD></TR><TR><TD CLASS="quote">mine did that at around 55, but it was due to my horribly unbalanced tires...but after speeding up it was better.
i would look into doing an alignment and balance/rotate tires, and suspension, before you start looking into the engine.</TD></TR></TABLE>
vibration at highway speeds is an unbalanced tire problem, def get em rebalanced and youll be all set. if not, then it could be ball joints.
spinnerator
Honda Civic (2001 - 2005)
22
Jun 1, 2011 10:08 PM
MazworxRacing
Welding / Fabrication
40
Feb 4, 2011 11:45 AM
ineedavtec
Jan 25, 2011 04:25 AM
Fat Chick Magnet
Aug 25, 2006 04:53 PM
Maxime
Dec 13, 2005 08:26 AM
