droppin tranny tonight help
k im swapping tranny's onto a z6 and I need to drop my tranny from my d15 thats in my car...question is can this be easily done with the motor in the car? can someone gimmstep by step of what I need to be taking off so I can unbolt thiranny tonight!
remove all the wiring. take off the starter. all the bolts n ****. the castlenut on the bottom to take off the axle. the fork thing that goes under the shock. then take out the axles use a punch dont hit directly with a hammer i got fawkd because of this mushroomed inside hub. pry the axles off do not pull it mite fawk up the axle. umm let see yea just take offf all the bolts. the shift linkage i unhooked it from the shifter and dropped it with the shift linkage. good luck mang
civicgsr2004
May 26, 2005 04:47 PM
