Can i bypass knock sensor on 94 GSR?
Old Jul 15, 2004 | 04:40 PM
ForgedSleeper's Avatar
Default Can i bypass knock sensor on 94 GSR?
I have a boosted 94 GSR that is throwing a knock sensor CEL. Is there any possible way to bypass it by taking it out and grounding it or something cheap and easy besides getting the ECU chipped. I cant dyno it while it throws codes. Thanks for the help!!!
Old Jul 15, 2004 | 05:52 PM
Padawan's Avatar
Darth ModerVader
Default Re: Can i bypass knock sensor on 94 GSR? (ForgedSleeper)
Have you determined why it's throwing the code?
Old Jul 15, 2004 | 05:56 PM
Marauder's Avatar
Default Re: Can i bypass knock sensor on 94 GSR? (Padawan)
Fix the problem. Without the sensor, it wont correct the timing and you will get engine knock.
Old Jul 15, 2004 | 07:56 PM
patmcd's Avatar
Default Re: Can i bypass knock sensor on 94 GSR? (Marauder)
Some how Id think you would want to fix the problem, not just ignore it.
Old Jul 16, 2004 | 10:03 PM
cyr0ch's Avatar
Default Re: Can i bypass knock sensor on 94 GSR? (patmcd)
Try running Premium Gasoline
luv2boost
Jul 5, 2007 09:43 PM
ForgedSleeper
Jul 27, 2004 04:12 PM
Formula 1
Oct 24, 2003 09:52 PM
