Bearings for Full Race/Manley Rods?
I was not able to find an answer searching and I have not gotten a response from them. I bought a set of bearings for Eagle Rods, but then sold them. I know the Eagles were #3. Now that I have the Full Race/Manley, should I assume they are #3 as well. I plan to use plastigauge, but wanted to see if some one had an answer before I started to assemble everything.
Last night, I checked the clearance for my GSR Manley turbo rod with acl bearing. They came out to be 0.0015 for all four. My crank code for the rod jounals are C.
Edit.
Modified by porsche997 at 1:21 PM 7/16/2004
Edit.
Once again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Thanks, but I'm using OEM Honda bearings. Anybody with OEM Honda bearings have any idea?</TD></TR></TABLE>
Use your old set of rod bearings to plastigauge then buy new ones based on the old bearing thickness, the clearance the plastigauge shows and the clearance you want to run. (simple math)
