Removing window tint from my ITR...
Old Jul 15, 2004 | 02:02 PM
REDTOPAlchemy's Avatar
Default Removing window tint from my ITR...
I got some window tint in my used ITR (actually looks pretty good). I was wondering, for future reference, is there an easy way to remove window tint without destroying my interior with messy chemicals or scratching my windows up with razorblades. It looks like the stuff I have is the film type.
Old Jul 15, 2004 | 02:07 PM
cannan's Avatar
Default Re: Removing window tint from my ITR... (PYXITR)
Dont do it unless you really want it off eventually. Then take it to a shop that does window tint. They have a hot steam gun thing that will get if off without stratching the window or getting chemicals in the car. It will cost you $$$ though
Old Jul 15, 2004 | 02:13 PM
Mugen Mike's Avatar
Have a prefessional window tinting shop remove it, or get there advice on the best removal process.
Old Jul 15, 2004 | 02:58 PM
atc5's Avatar
Default Re: Removing window tint from my ITR... (Mugen Mike)
i got tint removed from an EK, cost me $80 for the entire car. well worth it, i hate tint
Old Jul 15, 2004 | 04:05 PM
Rene M's Avatar
Default Re: Removing window tint from my ITR... (atc5)
This will blow your mind but i saw a guy take a spray bottle full of water and get the tint all wet then press a garbage bag on it and let it dry. he just pulled all the tint right off. When it got stuck he would spray a bit of water on the glass.. It was a clean job..
I just stood there with my mouth open..
Old Jul 15, 2004 | 04:08 PM
Sam's Avatar
Sam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atc5 &raquo;</TD></TR><TR><TD CLASS="quote">i got tint removed from an EK, cost me $80 for the entire car. well worth it, i hate tint</TD></TR></TABLE>
Can you tell us why you hate tint?
Old Jul 15, 2004 | 04:16 PM
crafty's Avatar
Default Re: Removing window tint from my ITR... (Rene M)
I just removed window tint on my accord last week....
I used a heat gun, and all it did was make it smell bad....
took out a brand new razor blade and sprayed a lot of windex and it came out perfect....
The back window is a different story.....
peel the tint off and instead of a razor blade use this
Old Jul 15, 2004 | 04:18 PM
crafty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">This will blow your mind but i saw a guy take a spray bottle full of water and get the tint all wet then press a garbage bag on it and let it dry. he just pulled all the tint right off. When it got stuck he would spray a bit of water on the glass.. It was a clean job..
I just stood there with my mouth open.. </TD></TR></TABLE>
But the glue was still stuck to the window right?
Old Jul 15, 2004 | 05:06 PM
mikesaRRRR's Avatar
Default Re: Removing window tint from my ITR... (crafty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crafty &raquo;</TD></TR><TR><TD CLASS="quote">
But the glue was still stuck to the window right?</TD></TR></TABLE>
yes go to pep boys .. and buy a clay bar usually used to take contaminates out of paint... used the lube and the bar on the window to get the sticker gunk off... it will come right off with no effort.... gunk be gone you have to rubb so hard you will lose your arms
Old Jul 15, 2004 | 05:37 PM
migs's Avatar
I removed my tint in under 3hours myself. Just get a really fine grade scotch brite pad and some windex. My rear defroster still works and the glass is not scratched.
Old Jul 15, 2004 | 06:41 PM
Del Sizzle's Avatar
Like Rene said if your not going to go to a professional the trash bag a solution works great. However if I were you I'd pay a tint shop to take it off.
Old Jul 15, 2004 | 08:53 PM
Default Re: Removing window tint from my ITR... (Del Sizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sizzle &raquo;</TD></TR><TR><TD CLASS="quote">Like Rene said if your not going to go to a professional the trash bag a solution works great. However if I were you I'd pay a tint shop to take it off.</TD></TR></TABLE>
I hear that....if I F my car up worse than it already is I will have to kill myself!
Old Jul 15, 2004 | 08:57 PM
KOALA YUMMIES's Avatar
You guys are hilarious
I recently removed some from my ITR as well. Side windows came off so incredibly easy. Cut a line with a razor blade and pull. Seriously no residue was left over.
The rear windows are more trickey. Did the same method however it split a lot more. Windex removed the leftover gunk, never needed ammonia or trash bags or all that other stuff. I spent a couple hours online searching for tips and how-to's and when i just sat down and did it it came out perfectly.
The rear defroster still works perfectly and the tint is all gone.
Old Jul 15, 2004 | 09:07 PM
sackdz's Avatar
Default Re: Removing window tint from my ITR... (KOALA YUMMIES)
i found that its best to peel it when its cool. if the sun is on it or its hot out the glue will be left behind more. hose the windows down before you do it to help cool them. i tried windex and ammonia with razor blade and still cant get the **** off the hatch glass. so i left it.
Old Jul 15, 2004 | 10:41 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">You guys are hilarious
I recently removed some from my ITR as well. Side windows came off so incredibly easy. Cut a line with a razor blade and pull. Seriously no residue was left over.</TD></TR></TABLE>
I did the same thing when I wanted to have the windows retinted, slight cut to get a grip and pull. works just fine.
Old Jul 15, 2004 | 10:56 PM
cheezthis's Avatar
Default Re: Removing window tint from my ITR... (Bbasso)
I used a garment/curtain steamer from wal-mart (super cheap)...came right off w/no issues.
Old Jul 16, 2004 | 05:02 AM
ebelp's Avatar
Default Re: Removing window tint from my ITR... (cheezthis)
You'd have to be pretty careless with the razor blade for it to scratch your windows. I've removed tint several times off different cars and it's not that hard. Lots of Windex and a razor blade do the trick nicely. The only part I'd be careful of is the rear window because of the defroster. I'd have a shop do that.
KAYTHAN
Sep 11, 2004 08:30 AM
JdmLsPwr425
Mar 10, 2004 07:34 PM
batman21
Jan 25, 2004 08:17 PM
LOWLIFEHATCH
Aug 20, 2002 07:25 AM
IdotheSHOCKER
Jun 1, 2002 05:00 AM
