fuel cut off
Old Jul 15, 2004 | 12:20 PM
brett booth's Avatar
Default fuel cut off
8500 is most rs cut off right
so if i took my car in 3rd posibly past it
is it bad for it and what could come of it
Old Jul 15, 2004 | 12:30 PM
vtec.dc2's Avatar
Default Re: fuel cut off (brett booth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brett booth &raquo;</TD></TR><TR><TD CLASS="quote">8500 is most rs cut off right
is it bad for it and what could come of it</TD></TR></TABLE>
its unlikely to overrev unless you mishift.
how high did you rev it?
did you mishift or idid it seem like you hit rev limiter a little higher, like 8700rpm?
Old Jul 15, 2004 | 01:53 PM
Default Re: fuel cut off (vtec.dc2)
like i think i reved to like 8700 maby in third then in to forth
Old Jul 15, 2004 | 03:36 PM
Azcheron's Avatar
the REAL cutoff of an ITR is 8600
8400 redline, 8600 fuel cut
some people try to say its 8500 fuel cut and 8200 redline, but thats wrong
....i got the specs right here...
if ur fuel cut isnt at 8600...ur tach is probably wrong or ur car was chipped
go look at ur tach, the second red line is even at 8600, not 8500
Old Jul 15, 2004 | 04:14 PM
ZygSpeed's Avatar
Default Re: fuel cut off (Azcheron)
That being said, the tach is off by ~400RPM at that point (reads about 400 rpm higher than actual).
Old Jul 15, 2004 | 04:19 PM
DC2fanboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azcheron &raquo;</TD></TR><TR><TD CLASS="quote">the REAL cutoff of an ITR is 8600
the tach signal reads ~8650 peak on the vafc after you bounce I'd attribute it to the fuel cut being hit at 8600 and "shutting" it down for the next 50 revs .
Old Jul 15, 2004 | 04:34 PM
B2FiNiTY's Avatar
The stock tach is not accurate at high rpms/speeds. I used to be able to hit 9000+ all the time, it was great.
Old Jul 16, 2004 | 03:49 PM
Ill's Avatar
Ill
Default Re: fuel cut off (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">The stock tach is not accurate at high rpms/speeds. I used to be able to hit 9000+ all the time, it was great. </TD></TR></TABLE>
Second (third?) that. Mine's 400 off (high) above 6500, porbably more. I thought I overrevved once, but I've never hit rev limiter or fuel cut.
Old Jul 16, 2004 | 05:25 PM
Dr Pooface's Avatar
Default Re: fuel cut off (Ill)
My stock tach is DEAD NUTS accurate.
Old Jul 16, 2004 | 05:35 PM
Utilitarian's Avatar
Go to an autocross, listen to people (experienced drivers) bounce off their rev limiters numerous times, then you'll rev the hell out of your engine with no worries.
Old Jul 16, 2004 | 10:34 PM
Bonez21's Avatar
Default Re: fuel cut off (Utilitarian)
my Tach goes crazy around 4k rpms it goes waaaay past the 10k mark sometimes
i'm trying to find a new one as we speak
Old Jul 16, 2004 | 11:11 PM
epy's Avatar
epy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Go to an autocross, listen to people (experienced drivers) bounce off their rev limiters numerous times, then you'll rev the hell out of your engine with no worries.</TD></TR></TABLE>
I completely agree haha. I remember seeing countless Z06's hit the rev limiter at the end of their run (on a strait)
Old Jul 17, 2004 | 09:03 AM
Twin-cam's Avatar
EU, JDM itrs cuts at 8900 rpms.
Old Jul 17, 2004 | 09:05 AM
Dave-ROR's Avatar
According to Honda (expo contacts and press releases) it's 8500 cut. 8400redline of course. :Shrug: I'll still take what honda says over helms (who has the GS-R info wrong too..)
Old Jul 17, 2004 | 10:20 AM
Twin-cam's Avatar
Most of the time its redline + 500rpms = fuel cut.
AFAccord
Nov 8, 2006 05:51 AM
LillDragun
Jan 21, 2003 10:49 PM
itr1244
Sep 15, 2002 09:16 PM
Tommy_Gunns
Jul 28, 2002 03:11 PM
HX_Guy
Aug 6, 2001 12:01 PM
