Questions about engine pinging...
Old Jul 15, 2004 | 11:41 AM
REDTOPAlchemy's Avatar
Default Questions about engine pinging...
My B18C5 is making a rattling/tapping noise (its not too loud like engine knocking) when I press the gas and maintain present gear (not when downshifting or upshifting); especially when going uphill. Almost sounds like the engine is going to stall. I have three questions involving engine pinging:
1)What is it? From what I hear, its the slapping sound of the connecting rod and crank journal when there's too much play.
2)What causes it? Improper spark plugs? Hard driving?
3)How can it be fixed/resolved.
Modified by PYXITR at 10:20 PM 7/15/2004
Old Jul 15, 2004 | 11:45 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
stop driving it now
Old Jul 15, 2004 | 11:57 AM
Bbasso's Avatar
Default Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">stop driving it now</TD></TR></TABLE>
Yeah I would have to agree! You might want to have a mechanic look at it before you start it again.
without seeing it or hearing it I could not say what wrong.
Old Jul 15, 2004 | 12:02 PM
Chris F's Avatar
Default Re: (Bbasso)
Hope it's not a rod knock.
When did it start? After doing something at high RPMs?
Old Jul 15, 2004 | 12:04 PM
Big Phat R's Avatar
Default Re: Questions about engine pinging... (PYXITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PYXITR &raquo;</TD></TR><TR><TD CLASS="quote">My B18C5 is making a rattling/tapping noise (its not too loud like engine knocking) when I press the gas and maintain present gear (not when downshifting or upshifting); especially when going uphill. Almost sounds like the engine is going to die. I have three questions involving engine pinging:
3)How can it be fixed/resolved.</TD></TR></TABLE>
1) Is this with the stock header or an aftermarket one? Aftermarket headers resonate from the exhaust pulses in the engine at a certain rpm usu 3500 or so.
2) pinging is caused by a number of things usually inadequate octane
3) depends
Old Jul 15, 2004 | 12:24 PM
Default Re: Questions about engine pinging... (Big Phat R)
Update: My ITR is second hand and the pinging has been present since I've had the car. Right now I am using 91 Octane Chevron Supreme, the plugs are the OEM NGK PFR6G-11. I've never taken it past redline myself but I cannot speak for the previous owner...from the looks of it he drove the car pretty hard. Besides the noise the car runs OK. It stalls after reving the engine for a little while (ie. during a collent flush)...but I thought that may be attributed to a Aftermarket lightweight FW becuase rpms drop faster. It sounds like this is some serius ****. Is there anything I specifically should test for? What could be my problem? Also, the sound was there before I did a valve adjust. The valve adjust did make my cold morning startups a bit noisy though (I'm guessing the valving train). Im using a stock, or what I thought was stock--looks like there is an LS header on my car--exhaust manifold and the TB is def. not an ITR. The intake arm side bore measures 58mm and not 66mm.
Old Jul 15, 2004 | 12:49 PM
bump...help, now you guys got me scared
Old Jul 15, 2004 | 01:07 PM
Runnerdown's Avatar
Might want to check the timing. I've seen morons turn distributors all the way and do that.
Old Jul 15, 2004 | 01:10 PM
Default Re: (Runnerdown)
Just replaced timing belt, tensioner and water pump and then timed the engine and did a valve adjust. Engine is still making the noise. Hard to notice both inside the car and outside. Have to be listening for it.
Old Jul 15, 2004 | 01:32 PM
PlastikOwl
Guest
Posts: n/a
Default Re: (PYXITR)
could be ignition...
Old Jul 15, 2004 | 01:38 PM
Default Re: (PlastikOwl)
I replaced sparkplugs, distrib. cap, rotor, and wires. Are you referring to the coil or something? Thanks for the input though. Can someone specify what part of the ignition system?
Old Jul 15, 2004 | 01:58 PM
Is there any test I should be performing short of an engine rebuild?
Old Jul 15, 2004 | 02:51 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: (Rguy)
anytime your engine is making noise, quite driving it!!!
Old Jul 15, 2004 | 03:24 PM
Default Re: (SpoonDC2R)
I dont have a choice. The ITR is my daily driver. The noise doesn't sound too bad, just annoying. F$@k, if the engine blows....well....the engine blows, and I'll be on the market for another B18C5. I don't really have a choice. My preference would be to fix the engine I have and if it is in fact pinging, find out what might be causing it. Any more suggestions???
Old Jul 15, 2004 | 03:54 PM
Big Phat R's Avatar
Diagnosing engine problems over the internet is useless. Too many possible variables.
Get your car looked at by a mechanic - you have no other choices.
Old Jul 15, 2004 | 07:34 PM
Fuuma0083's Avatar
Modified by PYXITR at 10:20 PM 7/15/2004</TD></TR></TABLE>
My friends' celica just blew his engine at the track because of that.
Could it possible be your valve needs adjusting?
Old Jul 15, 2004 | 08:49 PM
Default Re: (Big Phat R)
For some reason I can't reply to the next post. Ill do it here. I already adjusted valves. The noise hasn't changed in rhythem or volume. I guess you guys are right, the only thing to do is to see the mechanic. F@$k, 120$ inspection fee...here I come. Thanks for your input guys!
Old Jul 15, 2004 | 08:57 PM
Combustion Contraption's Avatar
$120 inspection fee
$a few grand for a new motor
your choice.
CHECK YOUR TIMING .... ive read through the thread and you still havent done it.
Old Jul 15, 2004 | 09:59 PM
ultimatehonda's Avatar
Well if you did all the mainentce work already then all a mechanic is going to tell you is that the noise is internal and you need a rebuild....If you have done everything that you can for now just ride it and see what happens. Maybe try running a compression test to see where you are at. Perhaps use some fuel additives to clean up the system.
curtie94
Dec 28, 2011 05:28 PM
CodeBlue
Honda Civic (2006 - 2015)
11
Feb 3, 2010 09:25 PM
jhammond_82
Oct 16, 2009 10:53 AM
92LudeSI
Aug 18, 2003 12:32 PM
Mover
Apr 3, 2002 08:56 PM
