When you overbore, do you also bore your HG?
Old Jul 15, 2004 | 08:42 AM
IloveNewt's Avatar
Default When you overbore, do you also bore your HG?
Im goin to 88.5 on my h23. For those with h series or whatever, do you guys just bore your stock hg as well?
Old Jul 16, 2004 | 01:48 PM
IloveNewt's Avatar
Default Re: When you overbore, do you also bore your HG? (MordecaiPSI)
bump
Old Jul 16, 2004 | 01:53 PM
SpdFrk's Avatar
I get the ones from GE, they are OEM bored out.
Old Jul 16, 2004 | 02:46 PM
Too_Smooth's Avatar
What's the stock bore on an H22? If it's 88mm you'll be okay. Stock headgasket's are .5mm over the original bore.
Old Jul 16, 2004 | 02:52 PM
SpdFrk's Avatar
Default Re: (Too_Smooth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Too_Smooth &raquo;</TD></TR><TR><TD CLASS="quote">What's the stock bore on an H22? If it's 88mm you'll be okay. Stock headgasket's are .5mm over the original bore.</TD></TR></TABLE>
H22/23's are 86.995mm bore stock.
Old Jul 16, 2004 | 10:43 PM
rmcdaniels's Avatar
I got the Cometic gasket when I got mine bored. They make ones for overbored engines. I've seen Mr. Gasket multilayer steel gaskets in overbore sizes for Honda/Acura engines also.
Pippen_001
24
Dec 9, 2006 06:24 PM
redlseg
Jul 18, 2005 09:10 PM
b16hybridsol
Jun 21, 2005 05:48 AM
m.
Nov 13, 2003 04:27 PM
KStuned
Jan 10, 2003 05:29 PM
