IDLING a little too high
Old Jul 15, 2004 | 05:43 AM
jdmcraze's Avatar
Default IDLING a little too high
ok when i first start my car idling is like 1300 then when warmed up
it stays at 1000 to 1100
ten when im driveing and let go of the gas the rpm drops to 1300
and will take a long time to settle at 1100
what can be the cause of it
i changed the plugs,wires,pcv,dizzy so what else could cause the problem
Old Jul 15, 2004 | 06:14 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: IDLING a little too high (jdmcraze)
Unplug your IACV sensor, while the car is running after it has warmed up to normal operating temp, look for a screw on the top left hand corner of the TB, turn the screw in until the RPMs drop to around 800-900 RPM
Old Jul 15, 2004 | 06:17 AM
HT Chaplain's Avatar
Loved
Default Re: IDLING a little too high (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Unplug your IACV sensor, while the car is running after it has warmed up to normal operating temp, look for a screw on the top left hand corner of the TB, turn the screw in until the RPMs drop to around 800-900 RPM</TD></TR></TABLE>
Are you talking about adjusting the IACV itself? Or the TB screw that adjusts the throttle spool
Old Jul 15, 2004 | 06:19 AM
Banned
Default Re: IDLING a little too high (LEGUTKI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LEGUTKI &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about adjusting the IACV itself? Or the TB screw that adjusts the throttle spool</TD></TR></TABLE>
Yeah, Adjusting on the throttle spool throws off the voltage on the TPS sensor.
Old Jul 15, 2004 | 06:32 AM
jdmcraze's Avatar
OK 'll try that and see if it works
thanks
Old Jul 15, 2004 | 06:42 AM
crx_88_si's Avatar
Are you talking about adjusting the IACV itself? Or the TB screw that adjusts the throttle spool</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, Adjusting on the throttle spool throws off the voltage on the TPS sensor.</TD></TR></TABLE>
I think he means the Idle Adjustment screw on the TB beside the RED Vac Line.
Lordofdark176
Oct 21, 2007 01:34 PM
WGFletch4WS
May 31, 2007 07:51 PM
d16vteceg
24
Jun 25, 2006 05:47 PM
AgentJam
Aug 2, 2003 01:23 PM
Prelude Vtec 23
Jul 10, 2003 02:12 PM
