who's removed there charcoal canister?
Old Jul 14, 2004 | 10:39 PM
JDMlyfestyle's Avatar
Default who's removed there charcoal canister?
Ive been searching around and i havent quite found out what negatives come with removing your charcoal canister. only experienced people reply. also the lines that go into the canister did u just plug them or did you leave them the way they were
Old Jul 14, 2004 | 11:12 PM
JSJ EG6's Avatar
Default Re: who's removed there charcoal canister? (JDMlyfestyle)
took mines out. i just left the lines how they were
Old Jul 14, 2004 | 11:41 PM
any other input on this?
Old Jul 15, 2004 | 07:25 AM
underpressure02's Avatar
I was wondering the same thing. I only have one line going to my can and it is the line from the fuel system back up. I believe it is a breather. Not sure if I should cap that off or leave it vent into the air. I am not sure if it needs to create a vaccume or build pressure.
Old Jul 15, 2004 | 07:45 AM
ajjohnsonnc1's Avatar
Default Re: who's removed there charcoal canister? (underpressure02)
I've been wanting to do this as well, but I was told this will throw a CEL. yes or no?
Old Jul 15, 2004 | 07:48 AM
Default Re: who's removed there charcoal canister? (ajjohnsonnc1)
I have aem ems so not worried about CEL. Just worried about it the fuel system will not build proper pressure.
eL's Avatar
eL
n00b question. Why ?
Old Jul 15, 2004 | 08:09 AM
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">n00b question. Why ?</TD></TR></TABLE>
I want to remove mine b/c all the other lines on it are blocked off. There is really no use for it in my car. Plus if I remove it I can then mount my catch can over in that area.
Old Jul 15, 2004 | 09:30 PM
anyone have a answer for me?
Old Jul 22, 2004 | 09:10 AM
G
sh!t happens.
Default Re: (JDMlyfestyle)
bump....i would like to know
Old Jul 31, 2004 | 11:10 PM
HYREV2NR's Avatar
Default Re: (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">bump....i would like to know</TD></TR></TABLE> Me 2!
Old Jul 31, 2004 | 11:47 PM
damn still no one has a answer for this?
Old Jul 31, 2004 | 11:50 PM
Tad's Avatar
Tad
its a tough question, be patient
Old Aug 1, 2004 | 12:09 AM
elwood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">damn still no one has a answer for this?</TD></TR></TABLE>
I dont have a very good one, but meh....too bad.
So I took mine out when I was spiffing up the engine bay,
but I was just flying through everything tyring to get the thing
running again, then I crashed it the next day, so its all a bit of a blur.
I took it out and looped the line to the intake manifold. It was on my
92cx, so no plugs or anything like on the 6th gens. It was very easy,
I cant belive I dont remember what exactly I did.
I didnt drive around long enough to decide if it made a difference,
but a lot of people say that they smell the gas fumes with out it.
Old Aug 1, 2004 | 09:14 PM
bigxclumzy's Avatar
won't pass smog visually. on average would waste about .3 gallons per tank.
Old Aug 1, 2004 | 09:16 PM
eL's Avatar
eL
n00b question #2. What does it do?
Old Aug 1, 2004 | 09:33 PM
Donkey85's Avatar
Default Re: (eL)
it absorbs the fuel vapors instead of them going into the engine bay. but after being a few years old i dont see it really doing you good anyhow
Old Aug 1, 2004 | 09:57 PM
eL's Avatar
eL
How does it help and can you replace it?
Old Aug 2, 2004 | 10:08 AM
Donkey85's Avatar
Default Re: (eL)
how does it help? by cutting down on emissons, not letting fuel vapors to the atmosphere
can it be replaced? yes i can be replaced but if memory serves me right they are not cheap
Old Aug 2, 2004 | 10:12 AM
Deemeetree's Avatar
Electrician
New one for $155 from slhondaparts.com
Definitely not cheap. Just leave it alone.
Old Aug 2, 2004 | 10:14 AM
dantastic's Avatar
i remember reading threads on h-t about removing it without any ill affects. keep in mind that most obd0-1 jdm cars dont have them. i would assume that if the nipples on the TB and i/m were capped off and the evap purge solenoid was left plugged in, you wont have any problems ditching the can. just keep it for smog
91 b20 integra
Oct 28, 2014 01:30 PM
Lost_clearance
Mar 25, 2007 07:38 PM
Boosted Chemist
Apr 19, 2006 03:33 AM
Drag-Accord
Feb 4, 2005 02:47 PM
Joon525
Jun 17, 2003 08:13 PM
