Vtec not engaging like it should!!! HELP!!!
Old Jul 14, 2004 | 10:20 PM
Bonez21's Avatar
Default Vtec not engaging like it should!!! HELP!!!
drives fine until vtec engages and then when engaged it makes a sort of popping noise and it kind of slows down a bit. I'm afraid to push it too hard because it does not sound good does this sound familiar to anyone??? I haven't had time to trouble shoot so i thought i would ask you guyz 1st
P.S. Just changed oil yesterday and it was a bit low after about 2700 miles of Mobil 1 i'm guessing its the sprak plugs my brother who works at Honda suggests i change them but i want to be sure before i go wasting money on something thats not causing the problem
Old Jul 14, 2004 | 10:21 PM
Bonez21's Avatar
Default Re: Vtec not engaging like it should!!! HELP!!! (Bonez21)
if its of any help its a 97 itr motor in a 93 hatch running off a chipped P28 set to itr specs
Old Jul 14, 2004 | 10:22 PM
InsertRacialSlur's Avatar
* B A N N E D *
Maybe you ran it too hard before the new oil began to circulate?
Maybe you used the wrong oil?
I dunno.
Old Jul 14, 2004 | 10:23 PM
Opie's Avatar
Bad Vtec solenoid possibly. Hope that motor is legit
Old Jul 14, 2004 | 10:25 PM
* B A N N E D *
I couldn't help but notice this ad at the bottom of the page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gay Ricer Ad &raquo;</TD></TR><TR><TD CLASS="quote">Buy Altezza Taillights
Choose APC, Carwear, Ichiban, TYC Elegante, Matrix, 2 Fast 2 Furious</TD></TR></TABLE>
Old Jul 14, 2004 | 10:26 PM
Bonez21's Avatar
Default Re: (opie)
haha everytime i post u say that opie itz legit maan lol i used Mobil 1 10w30
but do vtec solenoids go all of a sudden because this was like an over night thing
Old Jul 14, 2004 | 10:28 PM
* B A N N E D *
Maybe the life of the solenoid was slowly deteriorating, and then it just decided to go.
Any oil leaks or anything? The popping sound could be the release of pressure. Maybe a hole? I don't know, ahhhh! *dies*
Old Jul 14, 2004 | 10:35 PM
Bonez21's Avatar
Default Re: (TypeRWanter)
no leaks at all anti freeze was a little low but got filled today but other than that itz clean
this happened before and i had someone take the soleniond off and check it out and they looked at me and said i had the cleanest damn solenoid they've ever seen
gave the oil plenty of time to circulate it sounds as if something is wrong with the air flow or like there's a whole in something man i dunno lol no one has had this problem?!?!?!?!?!
Old Jul 14, 2004 | 10:43 PM
Opie's Avatar
Well, dumb question but whats your oil level now? Did you check it after your change yesterday? Sorry I can't help further but give it until morning and someone else may be able to help you.
Some people actually sleep at night
Old Jul 14, 2004 | 10:47 PM
cheezthis's Avatar
Default Re: (opie)
If your plugs were bad, you'd probably notice it in the low rpms as well. Try a different ECU and double check all of your grounds (trans, everything).
Oh...and change your vtec bearing
Old Jul 14, 2004 | 10:55 PM
Opie's Avatar
My money is on a faulty hen weigh.
Old Jul 14, 2004 | 10:58 PM
* B A N N E D *
My money is on opie being right! (I'm not mechanically inclined )
Old Jul 15, 2004 | 11:51 AM
Bonez21's Avatar
it was doing it earlier this morning but toward noon time it stopped wtf? maybe it was the oil circulation thing but i don't get it? 2 dayz to circulate??? the noise went away but it still doesn't feel healthy
Old Jul 15, 2004 | 01:04 PM
Ill's Avatar
Ill
Default Re: (Bonez21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 &raquo;</TD></TR><TR><TD CLASS="quote">haha everytime i post u say that opie itz legit maan lol i used Mobil 1 10w30
but do vtec solenoids go all of a sudden because this was like an over night thing</TD></TR></TABLE>
:edit: Check you got the right oil filter too.
Go read the 'great oil debate' post. I thought we were supposed to run 5w30. Dunno if that would be a problem or not.
If it happened before, I'd suspect VTEC solenoid, or more likely, a wiring problem. Check all your connectors are tight. Check any splices. This is where I would focus on a swap with an intermittent problem such as this.
Wash the motor after the oil change? Yank on any wiring during the last work session?
Low antifreeze in the bottle or in the rad? Engine probs + low coolant = suspect head gasket. I use NO coolant. How long since you last checked coolant level? How low is 'a little low' on the coolant? Any oil sheen or droplets in the rad (check with cap off, engine running). Any white residue on the bottom of the oil fill cap, dipstick, or moisture in the oil?
Modified by Ill at 2:44 PM 7/15/2004
Old Jul 15, 2004 | 02:40 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (Ill)
2 legit to quit
Old Jul 17, 2004 | 05:45 PM
Bonez21's Avatar
Default Re: (v-attack)
hmm after all the debate and troubleshooting it was an electrical problem but.....(drum roll) it has something to do with the fuel pump the little plug in the backseat has a small short in it so i had a friend move it around a little while i was in vtec and he could basically control how much fuel the motor got with a few wires
but thanks for all the help guyz you helped me narrow it down
P.S. so note for future references if there aren't any back seats then there shouldn't be any passengers back there haha lol might sit on my fuel pump again
TeggyBear_Ls
Dec 21, 2009 03:03 AM
mitcho
Oct 16, 2007 09:56 AM
DC2_ITR
Apr 27, 2007 12:55 PM
Layziejoe775
Feb 5, 2006 11:33 AM
92GSR
Apr 28, 2002 10:06 PM
