Got a problem with my 92 GSR
Old Jul 14, 2004 | 09:26 PM
Methane2k2's Avatar
Default Got a problem with my 92 GSR
I am wondering why my teg's fan turns on soo quickly. it turns on like after half an hour of driving and i am wondering if this is normal and like it has never actually overheated on me . Am a Newbie at this so please give me some answers.
thanks.
Old Jul 14, 2004 | 09:40 PM
sticks5141's Avatar
Default Re: Got a problem with my 92 GSR (Db2_iNtEgRa)
I would say it is normal but depends on how you drive it but mine in my 92 with a b16a turns on quick
Old Jul 29, 2004 | 11:08 AM
AZTEKEF9's Avatar
check you coolant level if is low you might have a leak somewhere in the cooling system and thas y ur fan turns on often.... check to see if you have a leak when you parked the car after a long drive.....
Old Jul 29, 2004 | 12:45 PM
92_civic's Avatar
Default Re: Got a problem with my 92 GSR (AZTEKEF9)
I don't see anything wrong with the cooling fan coming on after half an hour of driving, it's gotta come on sometime, but if you want to investigate further, check your coolant level and cooling fan relay. also all of your connections on the coolant temp sensor
Old Jul 29, 2004 | 02:33 PM
RayB's Avatar
Sounds pretty normal. It's a whole lot better than it not coming on (I just spent last weekend troubleshooting that issue on my DA). As long as it doesn't stay on for extended periods of time after you turn the car off.
Old Jul 29, 2004 | 03:03 PM
Lex2Go's Avatar
Default Re: (RayB)
The secondary fan turning on after an one of driving is pretty normal.
hotcivicsi
11
Apr 9, 2009 06:19 PM
92fourdoor
11
Jun 15, 2008 04:56 PM
92integ_gsr
Sep 7, 2006 05:28 AM
petersayarath
Jun 16, 2005 04:59 PM
Nocturnal
Feb 22, 2004 08:48 AM
