need help bad please help me a.s.a.p tranny
Old Jul 14, 2004 | 07:13 PM
Icey112's Avatar
Default need help bad please help me a.s.a.p tranny
ok my tranny was makeing a loud rubbing noise from the tranny so i took it out and 3 teeth on the counter-shaft were broken so i bought a new one put it in and still makeing like a rubbing/ grinding noise and it gets lounder the higher the rpm the tranny is a b16a2 with a quafe smoe **** like that. I need help A.S.A.P i have a dyno appointment monday so if any body can help please thanks.
Old Jul 14, 2004 | 07:24 PM
mmuller's Avatar
Mad Scientist
Default Re: need help bad please help me a.s.a.p tranny (Icey112)
did you change the bearings?
Old Jul 14, 2004 | 08:23 PM
SiDelSol97's Avatar
What happend to the broken teeth from the shaft...did you find them?
Old Jul 14, 2004 | 08:28 PM
Icey112's Avatar
Default Re: need help bad please help me a.s.a.p tranny (SiDelSol97)
i herd the rubing/grinding noise from the tranny so i checked it out and 3 of the teeth your broken off inside.
bearing look ok and sound fine so i don't miss with them.
Old Jul 15, 2004 | 05:27 AM
Icey112's Avatar
come on some has to know some thing
Old Jul 15, 2004 | 05:33 AM
Sliced Beard's Avatar
Default Re: (Icey112)
we have tried....usually if there is something wrong with a transmission you can find out what teh problem is with a thourough inspection. almost any problem can eb found by moving ish and looking at it (of coarse you have to know what you are looking at)
Old Jul 15, 2004 | 12:11 PM
SuperTeg95's Avatar
bump for a guy in need
Old Jul 15, 2004 | 06:40 PM
mmuller's Avatar
Mad Scientist
Default Re: (SuperTeg95)
bearings....you checked them? how? just by looking at them and spinning them? bahh
If the teeth of the shaft were chewed up, then that means that the shaft went through some stress as well as the bearings...
Old Jul 15, 2004 | 07:21 PM
Icey112's Avatar
Yes i just looked at the bearings and was spinning them . I know first time with somthing like this. so should i replace the top bearings and the bottom bearings on the counter shaft and it makes the noise when i push the clutch in to and when im slowing down.
sohc_coupe24
Aug 15, 2005 01:08 AM
onetrueshyguy
May 6, 2005 09:48 AM
MasterSaif
Mar 15, 2004 08:20 AM
HXvtec
10
Oct 16, 2003 04:39 PM
