Look what I found when I removed my stock 96 spec JDM ITR oil pan!!!
Old Jul 14, 2004 | 06:00 PM
tvrsir's Avatar
Default look what i found when removedmy jdm 96 spec stock itr pan!!!
are thhe jdm ones like this or did i get lucky?
http://www.imagestation.com/my...92245
http://www.imagestation.com/my...92252
http://www.imagestation.com/my...92261
Old Jul 14, 2004 | 06:11 PM
B2FiNiTY's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (tvrsir)
Looks like a spoon one
Willard's Avatar
looks like you get lucky...
a little DYI action in da pan.
Old Jul 14, 2004 | 06:12 PM
GSRrR's Avatar
unlucky, that is a defective pan, send it to me...
BlueR's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (B2FiNiTY)
js racing oilpan looks exactly like that too
eitherway...you lucked out
Old Jul 14, 2004 | 06:16 PM
obd2gsr's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (GSRrR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR &raquo;</TD></TR><TR><TD CLASS="quote">unlucky, that is a defective pan, send it to me...</TD></TR></TABLE>
hahaha
yeah, defective, send here
Old Jul 14, 2004 | 06:27 PM
tvrsir's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (obd2gsr)
you two are cracking me up hahah. they are eone they're way.
to the others i think it's a diy job. doesn't seem like any otherspoon mugen or aj pan. man i'm happy for opening it up now. it getting high compression pistons in and all new seals and bearings. port cyl head. ferrea valves, and some toda b's. gonna be rocking.
Old Jul 14, 2004 | 09:21 PM
Stinkycheezmonky's Avatar
Suspetise...
You bought it with all that stuff on it? Good deal. Just make sure it's tuned correctly if that's the case. It'd be a shame to blow all that up.
Old Jul 14, 2004 | 09:42 PM
esponet's Avatar
i would check to see what else that motor came with.
Old Jul 14, 2004 | 10:00 PM
2fknlo's Avatar
Default Re: (esponet)
Can someone explain what the benefit of this is.
thanks
Old Jul 14, 2004 | 10:04 PM
Bbasso's Avatar
Default Re: (2fknlo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fknlo &raquo;</TD></TR><TR><TD CLASS="quote">Can someone explain what the benefit of this is.
thanks </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=764002 - Oil Pan Baffling
https://honda-tech.com/zerothread?id=493919 - Oil Pan Baffling
Old Jul 14, 2004 | 10:11 PM
InsertRacialSlur's Avatar
* B A N N E D *
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=493919 - Oil Pan Baffling</TD></TR></TABLE>
and you know this because your stock oil pan OWNED you .
Old Jul 14, 2004 | 10:14 PM
Bbasso's Avatar
Default Re: (TypeRWanter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRWanter &raquo;</TD></TR><TR><TD CLASS="quote">
and you know this because your stock oil pan OWNED you .</TD></TR></TABLE>
Huh??
Old Jul 14, 2004 | 10:21 PM
* B A N N E D *
In the first thread you posted, you talked about how you starved your engine of oil due to your oil pan not being baffled .
Old Jul 14, 2004 | 10:27 PM
MAD ITR 55's Avatar
Looks like it was your lucky day
Old Jul 14, 2004 | 10:39 PM
Bbasso's Avatar
OH!!! I see... me not smart...
stock pan owned me...
Old Jul 15, 2004 | 04:36 AM
mugenracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Looks like a spoon one </TD></TR></TABLE>
So Spoon dont actually make their own...they just take an OE one and weld in the plates to baffle it????
Old Jul 15, 2004 | 04:54 AM
ragejed's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">
So Spoon dont actually make their own...they just take an OE one and weld in the plates to baffle it????</TD></TR></TABLE> That is correct
Old Jul 15, 2004 | 05:22 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">So Spoon dont actually make their own...they just take an OE one and weld in the plates to baffle it????</TD></TR></TABLE>
Same with m00gen
Old Jul 15, 2004 | 06:25 AM
Dogginator's Avatar
Daisy... Daisy...
I personally have not seen a Spoon or Mugen baffled pan. Is this the quality that they would produce? It looks like this was done by a HS student in shop class with an oxy-acetylene torch. (It is brazed, not welded.) Heck, there are wire wheel scratch marks all around the brazing.
Regardless, the baffles will do the same job, despite the looks.
Old Jul 15, 2004 | 06:33 AM
.RJ's Avatar
.RJ
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (Dogginator)
Mugen pan - https://honda-tech.com/zerothread?id=758856
Old Jul 15, 2004 | 07:20 AM
Suspetise...
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (.RJ)
There have been comparisons of the Mugen and Spoon pans in the past, and the Mugen ones seem to always look much more professionally built, while the Spoon ones look more cobbled together.
Old Jul 15, 2004 | 08:14 AM
Racebrewer's Avatar
Default Re: look what i found when removedmy jdm 96 spec stock itr pan!!! (sscguy)
Just a thought. I can see the 'horizontal. baffle plates that stop the oil fron leaving the pick-up under braking and accelleration, but I can't make out any vertical plates that would direct the oil to the pick-up under cornering (check out the Mugen pics as there should be vertical fins above and below the horizontal plate.).
While you have the pan off, you might want to add those plates.
In regards to brazing, done properly, there is little heat distortion and it is certainly strong enough for the application. IMHO, there is no need for the Bling-Bling of TIG inside the pan where nobody will see it.
John
Old Jul 15, 2004 | 04:15 PM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">I personally have not seen a Spoon or Mugen baffled pan. Is this the quality that they would produce? It looks like this was done by a HS student in shop class with an oxy-acetylene torch. (It is brazed, not welded.) Heck, there are wire wheel scratch marks all around the brazing.
Regardless, the baffles will do the same job, despite the looks. </TD></TR></TABLE>
That was my thought that is not a tig weld but brass...... Some one did that not a factory or a parts suppler. See the one lone weld to the side but not in a series that is bad and could cause a crack. Over heating only one spot and not welding for a longer run will super heat the metal and could pull through causing a hole to the out side world. A stitch weld needs to be longer and more systematic not just a tach weld.
While it is out i would have that done right. Sorry to rain on a good time..
Old Jul 16, 2004 | 09:04 PM
allmotorcx's Avatar
I hav one look just like it!!!!
