ecu codes
Old Jul 14, 2004 | 04:34 PM
89sirex's Avatar
Default ecu codes
alright, i just did a head gasket on my stock 89 si crx. now it throws a code but i don't know have a scanner.... someone told me about grounding out the plug and the check engine light will flash....i don't know where this plug is but my ecu is flashing 17 tims...i read about this vss thing but i can't get the idea am i on the right track and what can i do?
Old Jul 14, 2004 | 04:53 PM
mr. carpenter's Avatar
Default Re: ecu codes (89sirex)
you don't need a scanner. that's what the flashing light is for. code 17 is the vss which is the vehicle speed sensor. i don't see how changing out the head gasket would affect the vss. it's a black cable that comes out of the firewall at an angle and goes into the trans. by the mount. you might have knocked it loose. grounding out the plug to get the cel to flash is the diagnostic procedure for eg's.
Old Jul 14, 2004 | 05:23 PM
regime's Avatar
for the love of god SEARCH
Old Jul 15, 2004 | 01:39 PM
89sirex's Avatar
Default Re: ecu codes (regime)
sorry for not searching just wasn't thinking about it
Old Jul 15, 2004 | 02:01 PM
APEX CRX's Avatar
Aight we'll let you slide since you said sorry
Old Jul 15, 2004 | 02:30 PM
crx_88_si's Avatar
Default Re: ecu codes (APEX CRX)
just pull out the fuse marked HAZARD in the engine fuse box. wait 20 seconds and replace it. VSS comes on like 3 times a year in my car. only when it's REALLY hot outside and im decelerating in 4th. odd, but true.
Old Jul 15, 2004 | 04:24 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">Aight we'll let you slide since you said sorry</TD></TR></TABLE>
That's twice you have been unecessarily nice on here responding to newbs with ECU code questions.
You're fired.
Old Jul 15, 2004 | 04:34 PM
kshymkiw83's Avatar
Default Re: ecu codes (4drEF)
VSS just came on in my car as well. I just disconnected the ground and reset the ECU, hasn't came on since.
Old Jul 16, 2004 | 10:55 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
You're fired.</TD></TR></TABLE>
HA HA yeah usually I'm just as harsh as you. Must of been a off day LOL
Old Jul 16, 2004 | 12:11 PM
4drEF's Avatar
Keyboard Humorist
HA HA yeah usually I'm just as harsh as you. Must of been a off day LOL</TD></TR></TABLE>
Me posting on here is a stress release from the preasures gained at work.
Children under the age of 6 should not view my posts.
Possible brain damage or sever physcological disorders may result.
Old Jul 16, 2004 | 01:37 PM
APEX CRX's Avatar
HA HA yeah I understand I do the same cuz I'm surrounded by idiots asking idiotic questions at work so I gotta klash out when I see the same to on HT
CiViCShella
May 2, 2013 01:44 PM
RevrsOne
Oct 5, 2012 07:14 PM
boostng r
10
Nov 14, 2004 09:55 PM
bossman032
May 18, 2003 08:55 PM
Stu
Sep 1, 2001 09:09 PM
