did a compression test on d16z6 del sol
i'm lookin to turbo my z6 so figured i'd better do a compression test first. when the motor was cold i got 200-240-240-240 and with the engine warmed up i got 240 all across the board. is the 200 in the one cylinder while the engine was cold anything to be worried about?
edit-my friends compression tester is stuck at 30 psi so i'm not sure if that means mine actually turned out to be 210(240 minus 30)
Modified by PA MATT at 7:15 PM 7/14/2004
Robert Stern
Apr 16, 2013 04:49 PM
Skadaloz
Apr 8, 2008 10:02 AM
