99 usdm gsr swap in 2000cx hatch
Old Jul 14, 2004 | 02:42 PM
Silverhatch's Avatar
Default 99 usdm gsr swap in 2000cx hatch
I have a 2000cx hatch and Im putting in a 99gsr swap. what harness do i need ? I tired to plug the gsr ecu into the stock cx harness and only 2 connectors fit.. Will the ex one work ? and also is the wiringharness in 2 pieces ? Or does it come from the ecu straight to the sensors ? also where can I pick up a harness from anyone have one for sale ??? thanks
Old Jul 14, 2004 | 09:51 PM
daft's Avatar
Default Re: 99 usdm gsr swap in 2000cx hatch (Silverhatch)
im sorry... you need to do more research... 99 into 2000? uh uh...
Old Jul 15, 2004 | 04:54 AM
EE_Chris's Avatar
The '00 Integra shared the same ECU connectors as the 99-00 Civic.
The '98-'99 Integra shared the same ECU connectors as the 96-98 Civic.
I believe starting in '99 is when the Integra gained the immobilizer.
Old Jul 15, 2004 | 05:50 AM
deSigi's Avatar
Default Re: 99 usdm gsr swap in 2000cx hatch (EE_Chris)
96-98 Civic = A, C, D plugs ---> OBD2a
99-00 Civic = A, B, C plugs ---> OBD2b
94-98 Integra = A, C, D plugs ----> OBD2a
99-01 Intagra = A, B, C plugs ---> OBD2b
You can use your 2000 Civic harness.
Old Jul 15, 2004 | 06:31 AM
deSigi's Avatar
My bad, the 99 integra apparently is obd2a not obd2b. Which means it has the A, C, and D plugs.
Can anyone confirm this. I need another coffee!
If it is the case, you'll need a 96-98 civic harness.
Old Jul 15, 2004 | 07:02 AM
EE_Chris's Avatar
Default Re: (deSigi)
I personally own both the 98-00 Teg and 96-00 Civic ETM's....the info above is correct.
However, tyring to put a 96-98 harness into a 99-00 chassis is NOT the way to go.
You need a jumper harness.
And since you're dealing with a 99 GS-R ECU, you need to take care of the immobilizer as well.
Old Jul 15, 2004 | 07:05 AM
deSigi's Avatar
Default Re: 99 usdm gsr swap in 2000cx hatch (deSigi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deSigi &raquo;</TD></TR><TR><TD CLASS="quote">96-98 Civic = A, C, D plugs ---&gt; OBD2a
99-00 Civic = A, B, C plugs ---&gt; OBD2b
94-98 Integra = A, C, D plugs ----&gt; OBD2a
99-01 Intagra = A, B, C plugs ---&gt; OBD2b</TD></TR></TABLE>
I thought this was right. But he tells me that his harness doesn't fit in the the 99 GSR ECU. That's why I'm all confused now.
Old Jul 15, 2004 | 07:10 AM
EE_Chris's Avatar
Its partially right.
98-99 Integra = 96-98 Civic
00 Integra = 99-00 Civic
I don't know about the previous year Tegs - I don't own that Helms so I can't say anything about it.
As you can see, he owns a 00 hatch, which means only a 00 Teg ECU would plug directly in, however, he is using a 99 ECU...obviously, not compatible ECU connectors....need an intermediate harness.
Old Jul 15, 2004 | 07:21 AM
deSigi's Avatar
According to Helms, 94-95 is obd1 not obd2a (I gotta pay more attention when I type, my appologies). 96-98 is obd2a and it's unclear about the 99 teg, but I guess you cleared that up.
Old Jul 15, 2004 | 08:45 AM
VTECVillain's Avatar
Just to clear the OBD's up:
1992-95 Integra - OBD1
1996-99 Integra - OBD2A (OBD2)
2000-01 Integra - OBD2B (OBD2.5)
1992-95 Civic - OBD1
1996-98 Civic - OBD2A (OBD2)
1999-00 Civic - OBD2B (OBD2.5)
Old Jul 15, 2004 | 08:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silverhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000cx hatch and Im putting in a 99gsr swap. what harness do i need ? I tired to plug the gsr ecu into the stock cx harness and only 2 connectors fit.. Will the ex one work ? and also is the wiringharness in 2 pieces ? Or does it come from the ecu straight to the sensors ? also where can I pick up a harness from anyone have one for sale ??? thanks
You MUST use a 99-00 Civic harness only. The Integra harness WILL NOT work and neither will any other years Civic's besides the 99-00. For a GSR swap, the ideal harnesses would be either a 99-00 EX or Si for the most plug and play wiring. You'll need to only extend a few wires and add the IAB wiring. You can also use the stock CX harness and add the needed plugs/wiring as well.
The only way for the 99 GSR to work with your chassis (without a lot of headaches and rewiring) is to purchase an OBD2B to OBD2A ECU adapter harness.
94whiteSI
Aug 24, 2007 04:23 PM
GOLDBERG
Jun 21, 2005 10:17 AM
B18ek
Nov 27, 2004 07:39 AM
shadykit
May 12, 2004 05:22 PM
