i can't get my speedo cable to work!!
Old Jul 14, 2004 | 02:03 PM
1SIKCRX's Avatar
Default i can't get my speedo cable to work!!
is there a certian way it goes in the tranny? i kinda here a click when i get in there. and i then put the clip on. then go to drive the crx. and i get no movement on my speedo needle!!
i noticed there is a notch thingy on the one side of the end of the speedo cable. does that need to be faceing a certian way?
any idea's will help
thanks
oh i even move the crx back and forth while i'm putting in the speedo cable!!
Old Jul 14, 2004 | 03:50 PM
mr. carpenter's Avatar
Default Re: i can't get my speedo cable to work!! (1SIKCRX)
the only thing i can think you might be missing is there is a wire clip that holds the cable to the housing. it goes around the cable and in the slot on the left side in this pic.
Old Jul 14, 2004 | 04:01 PM
ServiceAdvisor's Avatar
Are you trying to use a CRX spedo cable in a YS1 LS tranny? Maybe you need the longer 90-91 LS spedo cable. Are you certain the end which plugs into the gauge cluster clicked in? Are you throwing a code 17 for VSS? More info plz. - Darrell
Old Jul 14, 2004 | 07:52 PM
1SIKCRX's Avatar
Default Re: (OldSiHatch)
mr. carpenter: yes i have the "U" shape clip. i get it to clip in and the cable stays. but it doesn't work!?!
OldSiHatch: yes i have a 89 crx si speedo cable. i have the 90 integra ls tranny. i'm not 100% sure it clicked in. but i think i heard it click in a few times!!! yes i'm throwing a code 17.
and to add. i checked behind my gauge cluster. to make sure the cable was still attach'd to it. and it is.
Old Jul 14, 2004 | 08:53 PM
CRX_Control's Avatar
Default Re: (1SIKCRX)
i had this problem a week ago and found out the what the problem was by taking my guage cluster out and the problem was that the speed cable was out of the cluster ,my speed cable was messed up so i went to the junk yard and bought one and fixed the problem in an instant.
Old Jul 14, 2004 | 10:52 PM
90civichbsi's Avatar
Default Re: (CRX_Control)
if its attached at both ends it could be a broken cable... i ran my 90 speed sensor in my s1 tranny for a couple years w/ no probs.
GPC91
Sep 17, 2012 01:11 PM
crxblues
Dec 6, 2006 10:44 AM
jcrou
Dec 17, 2004 08:56 AM
sleepin91teg
Apr 15, 2004 02:08 PM
Monty
Oct 5, 2002 09:46 AM
