question about pulling a vacuum on AC system
Old Jul 14, 2004 | 01:19 PM
Emery's Avatar
Default question about pulling a vacuum on AC system
Hi. I'm getting ready to evacuate my AC system with a vacuum pump. I've got the high and low side gauges hooked up, and the vacuum pump hooked up to the 3rd hose, and everything open. Is that all I need to do, before turning on the pump? The instructions for my gauges say something about opening up the discharge and suction service valves on the compressor. But, I don't see any valves on the AC compressor.
Perhaps that doesn't apply to my 93 Honda? Any advice is appreciated.
-Emery
Old Jul 15, 2004 | 01:13 AM
bigxclumzy's Avatar
Default Re: question about pulling a vacuum on AC system (Emery)
both valves are generally found in transport refigeration units. just open up your hand valves put in a vacuum and that should be fine. but you shouldn't use a vacuum pump to evacuate system, cuz all it does is vent refigerant into the atmosphere. it is harmful to the environment and illegal, but i've done it a few times.
NIKADEM0
Honda CR-V & Element
Jul 22, 2013 10:59 AM
josh_db1
Apr 24, 2010 11:19 PM
slockm
Jun 21, 2008 04:24 PM
LoneStarCRX
13
Apr 18, 2006 08:10 AM
littledan
Mar 18, 2005 03:10 PM
