rear disc brake conversion parts list
I have a 92 Civic DX, I just purchased a rear disc conversion from a 93 Integra. The parts included are rotors, calipers, hoses, trailing arms and pads. What all will be needed to sucessfully and effectively convert it from the drum system I currently have?
So far Ive found out that I need Integra E brake cables and getting SS brake lines would be worth my time, anything else?
Thanx in advance
Thanx in advance
Yes get the brake cable. Im assuming you have the whole trailing arm with the hub. also, you'll need a new proportioning valve im assuming. lucky you, you can get one from a Si hatch for your year.
You should have got them from a 94 and up integra. I think that the 90-93 integra are the ones that bolt up to the 88-91 crx's and civic hatches. Someone let me know if this is correct or not.
if you hvae a 92 dx you need
the rear trailing arm off of ANY 94-01 integra with the ebrake cable
ANY 94-01 integra brake booster, but a RS integra master cylinder(so the lines match up), and a prop valve from ANY 94-01 integra
WestSideRain
Apr 13, 2009 08:02 AM
LowFlyin'
Oct 20, 2003 03:49 PM
