195 50 15
Old Jul 14, 2004 | 12:23 PM
[HrZn]4life's Avatar
Default 195 50 15
just wondering if any of you guys know if 195 50 15 tires would be able to handle the load from dc chassis; keeping in mind that the load index on this size tire tends to be lower than 195 55 15. I just heard that this size tire with it's load index is meant more for civic hatches/smaller, lighter vehicle. Thanks guys.
Old Jul 14, 2004 | 12:27 PM
B2FiNiTY's Avatar
Default Re: 195 50 15 ([HrZn]4life)
I know of many people running that for a long time without a problem.
Old Jul 14, 2004 | 12:32 PM
Default Re: 195 50 15 (B2FiNiTY)
thanks...
Old Jul 14, 2004 | 12:45 PM
Hybrid ctr's Avatar
lots of people run that size with no problem(s)... just don't tell tirerack what car it's for
Old Jul 14, 2004 | 12:50 PM
DutchITR1689's Avatar
Just check the difference of the max load capacity on Tirerack, then you'll see how small the difference is......
Old Jul 14, 2004 | 12:53 PM
Wai's Avatar
Wai
ProFunction/GT Motoring
I think Chris N ran that size S03's on his R before; while there was no problem, he didn't like the feel of it.
Old Jul 14, 2004 | 02:33 PM
Chris N's Avatar
Default Re: (Wai)
I would not use a 195 50 15 on the track. I DID once, but it was my first event (i.e., I had stock pads, fluid, stock everything).
For the street I'd say they are fine. The load ratings are given for each car for a reason - and I'd be wary of using 195/50/15 on the track where you might be pushing the limits of the car (i.e., weight transfer, adhesion, etc).
Old Jul 15, 2004 | 09:27 AM
Default Re: (Chris N)
I actually ran 195 50 15 before but with really, really, really cheap tires. After a couple months of hard cornering I noticed that all the sidewalls had bubbles; I thought maybe it was just a really cheap tires but i'm suspecting that it was a combination of the lower load index and bad quality tires. Thanks for the input guys.
Old Jul 17, 2004 | 05:33 AM
Dirt's Avatar
Default Re: ([HrZn]4life)
I run 195/50 Pirelli PZeros on OEM wheels for street use. Great tire for $50 each (purchased at Tire Rack over a year ago, but now not available). I will probably go with 195/55 or 205/50 for my next daily tire.
Old Jul 22, 2004 | 10:39 PM
Slow_Em1's Avatar
run that in the rear and 205 in the front
eg.reddragon
May 17, 2013 12:22 PM
vidanator
Mar 21, 2005 08:16 PM
A.E Motoring
17
Sep 23, 2004 03:56 PM
BoostinEJ1
Mar 8, 2004 02:10 AM
B2FiNiTY
May 7, 2002 01:41 PM
