installing a new dizzy HELLLLP
Ok i need to replace my dizzy on my 91dx how do i install the new one
someone give me some ideas
sorry i'm a newbie here thanks in advance....
3 bolts out, unplug the 2 clipsm pull old dist out.
turn the new dist rotor to match the old one.
reverse process.
you are an idiot and dont deserve to change your own oil if you cant do this.
reverse process.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8LS-T »</TD></TR><TR><TD CLASS="quote">
you are an idiot and dont deserve to change your own oil if you cant do this.</TD></TR></TABLE>
so harsh yet so true.
give him a break. he's 17 and willing to admit he does'nt know. as mentioned the three screws hold it on. undo the electrical connectors. i'd go ahead and replace the cap rotor and wires while you're at it. get you a haynes manual for now. it'll be very helpful.
The screws that hold the dizzy on are usually a pain to get out.
You might have to use an impact driver is the hex heads strip out.
Unplug the connectors and remove the old one.
When you put the new one in, make sure the connection between the distibutor and the camshaft is correct. On some cars you can install it wrong and it looks right EXCEPT the distrbutor doesn't sit completely flucsh with the head. If that happens, remove it and rotate the distrbutor connction 180 degrees and try again.
Put the bolts in to hold it in place, but only tighten down loosely.
Put all the wires on.
Set timing (don't forget to disable the ignition advance.
Tighten down the mounting screws and you're done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">12 mm wrench also works to get the screws out.</TD></TR></TABLE>
Usually... until it strips the head off because it's in there so tight!
t0kyoStatus
May 9, 2008 11:32 AM
pythoner
Dec 7, 2006 10:47 AM
Xander teh Grate!
May 31, 2006 02:06 PM
gtowni3
Sep 24, 2004 12:12 PM
TooDrunk2See
Oct 1, 2003 09:25 AM
