Help Quick (IAT) sensor
Old Jul 14, 2004 | 09:07 AM
AMG's Avatar
AMG
Default Help Quick (IAT) sensor
Anyway to tell if my IAT sensor has gone bad just by looking at it? Im throwing this code and cant seem to find any breaks in the wires?
Im about to go get a new one from honda, but need to know if there is any way to check?
Thanks
Old Jul 14, 2004 | 09:21 AM
cxSHOE's Avatar
Default Re: Help Quick (IAT) sensor (dohcVTEChatch)
your better off getting one from the junkyard for $20 bucks instead of the dealership at $200.00+
Old Jul 14, 2004 | 09:26 AM
AMG's Avatar
AMG
Default Re: Help Quick (cxSHOE)
Its 61.00 @ my dealership......you may be thinking of a different part.
Ok well I am going to get the sensor now and hopefully it will fix the prob., but I have seen many of times people have this problem, replace the sensor and still have the code. This then means that wiring is the problem. We will see.
Ohh and should I reset my ecu after I put the new sensor on?
Old Jul 14, 2004 | 09:41 AM
cxSHOE's Avatar
Default Re: Help Quick (dohcVTEChatch)
yea im probably thing of the iac . what is the iat??
Old Jul 14, 2004 | 09:43 AM
eg92b16a2's Avatar
isnt that the "intake air temperture"
Old Jul 14, 2004 | 10:23 AM
AMG's Avatar
AMG
Default Re: Help Quick (eg92b16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg92b16a2 &raquo;</TD></TR><TR><TD CLASS="quote">isnt that the "intake air temperture"</TD></TR></TABLE>
Yep IAT......and I just got back with a new one and 65.00$ later
Anyhow I am letting the engine cool and then I will replace it, reset the ecu and hopefully it fixes the problem.
How should I reset my ecu (battery or ecu chip)? And how long should I let it sit?
Old Jul 14, 2004 | 10:29 AM
The Mista Mike's Avatar
Try this to reset your ECU:
Turn your key to the on position (just before it cranks)
Turn it off.
Do that three times and the ECU should be reset without disconnecting the battery or anything.
Old Jul 14, 2004 | 10:31 AM
AMG's Avatar
AMG
Default Re: Help Quick (Mistamike17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mistamike17 &raquo;</TD></TR><TR><TD CLASS="quote">Try this to reset your ECU:
Turn it off.
Do that three times and the ECU should be reset without disconnecting the battery or anything.</TD></TR></TABLE>
never heard of that...you sure
How long to I have to let the car sit before I drive it. Just wondering b/c doesnt the ecu have to sit with the car turned on for a while to erase all previous codes if fixed?
Old Jul 26, 2004 | 07:11 PM
mjrage's Avatar
did that fix your problem? I am also throwing code 10
Old Jul 27, 2004 | 10:21 AM
AMG's Avatar
AMG
Default Re: Help Quick (mjrage)
Nope..........must be the wiring
ek9adrian
Jul 31, 2007 10:38 PM
Hittnthebz
Mar 17, 2007 11:45 AM
beatthisspeed69
Mar 31, 2006 12:18 PM
hondaracing1
Nov 27, 2004 08:59 AM
kell211
Oct 5, 2003 05:59 AM
