FUEL INJECTOR SIZES AND SWAP INFO????
Old Jul 14, 2004 | 05:53 AM
SLOAZZ95's Avatar
Default FUEL INJECTOR SIZES AND SWAP INFO????
what is a d16z6 injector size(i.e. 210cc)? what injectors are direct plug and play for a 95 ex civic and what are their size? i belive that the 95 ex civic has peak and hold injectors if i am correct that is what this system has to have? am i correct in thinking this?
Old Jul 14, 2004 | 07:19 AM
SLOAZZ95's Avatar
Default Re: FUEL INJECTOR SIZES AND SWAP INFO???? (SLOAZZ95)
OK, seeing that i wasnt going to get any help from anyone on here, i went online and found that the stk is a 240cc injector and is saturated. so now that i know this hopefully somone can help me with what size injector i need ro my setup and will they be a direct plug and play with a stk chipped ecu??
Old Jul 14, 2004 | 08:26 AM
SLOAZZ95's Avatar
BUMP, ANYONE have any info on this. also what is the max fuel pressure a stk z6 injector can push without messing up.
Old Jul 14, 2004 | 08:35 AM
scratchy's Avatar
well you can only jump up an extra 30cc if you are running the stock computer but you can spend 350 on a v-tec afc and get some 440cc injectors for pretty cheap i have to check and see what my cost is on them, then you can run what ever you want and then you can actualy tune the thing but you will have to pull the chip more than likely
Old Jul 14, 2004 | 08:43 AM
SLOAZZ95's Avatar
Default Re: FUEL INJECTOR SIZES AND SWAP INFO???? (scratchy)
So then i could run the accel 255cc injectors as a plug and play and then bump up the fuel pressure to say 45psi???
Fuel Injector Clinic
Sep 29, 2014 06:14 AM
boostedteg4dr
Nov 30, 2013 01:17 PM
tuck1crx
Nov 11, 2010 11:54 AM
URNVS
Jul 1, 2006 03:41 PM
