TODA Competition Header / Fujitsubo RM-01A
Old Jul 14, 2004 | 12:02 AM
Hacemuy's Avatar
Default TODA Competition Header / Fujitsubo RM-01A
I have decided that I want to upgrade the exhaust on my ITR, and have narrowed it down to this:
TODA Competition Header and a Fujitsubo RM-01A cat-back
I chose the header because I have heard great things about power gains, especially in the midrange. The good ground clearance also appeals to me. The exhaust I chose because of the quieter sound and good reviews. Both products sound like top-notch quality.
My car is a daily driver so I value a quiet system. I autocross at least once a month as well and will begin tracking the car come August.
My question is:
What type of cat would I use to connect the two ends? Are there any other fitment problems that may arise using these two products?
Any other comments/suggestions are welcome regarding this exhaust system.
Old Jul 14, 2004 | 12:59 AM
passwordjdm's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (Hacemuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hacemuy &raquo;</TD></TR><TR><TD CLASS="quote">What type of cat would I use to connect the two ends? Are there any other fitment problems that may arise using these two products?</TD></TR></TABLE>
JDM ITR cat, direct bolt on
Old Jul 14, 2004 | 06:52 AM
AamirCWITR's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (passwordjdm)
SMSP JDM length cat, that is what i use with my RM-01A and 2.5" header.
Old Jul 14, 2004 | 07:12 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: TODA Competition Header / Fujitsubo RM-01A (AamirCWITR)
Does the OEM JDM ITR cat have the 2.5" outlet or whatever to properly mate to the 2.5" collector on the header? I know SMSP's does, but not sure about Honda's.
Old Jul 14, 2004 | 07:16 AM
thk's Avatar
thk
Members Only
JDM ITR cat works.
That's what I'm using with the Toda header / RM-01A combo.
Old Jul 14, 2004 | 08:03 AM
Suspetise...
Default Re: TODA Competition Header / Fujitsubo RM-01A (thk)
Is that cheaper than the SMSP one? And if it is, where can I get one?
Old Jul 14, 2004 | 02:41 PM
Hacemuy's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (sscguy)
Is there much of a performance difference between an SMSP cat and a JDM ITR cat?
Also, will I get any CEL using these pieces or is there any modification of the o2 sensors needed?
Thanks for the help.
Old Jul 14, 2004 | 02:42 PM
B2FiNiTY's Avatar
The JDM ITR cat doesn't have any 02 bungs so you will have to have one welded on.
Old Jul 14, 2004 | 03:34 PM
PIMPAZZITR's Avatar
I use to run that header on my race car it shows gains of about 30hp to the wheels allowing you tune it for about 17.5 - 1 Air fuel ratio.
Old Jul 14, 2004 | 04:43 PM
xc1097's Avatar
Default Re: (PIMPAZZITR)
get car sound cat
once a while i get check engine light w/ code p0420 which is
cat system efficiency below threshold (bank1)
but just clear/reset the ecu w/ obd2 connector and it goes away
just did that today too for getting state inspection
by the way, new MASS law which changed about 2weeks ago says any car w/ check engine light will fail inspection automatically
Old Jul 14, 2004 | 04:45 PM
xc1097's Avatar
Default Re: (xc1097)
by the way i run TODA header w/ TOPFUEL exhaust setup
once a while when i shift from 3rd to 4th at 8400rpm, i get flame come outa my exhaust
it's almost stock car w/ no backfiring system or some sort
Old Jul 14, 2004 | 04:47 PM
FerioVtec94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIMPAZZITR &raquo;</TD></TR><TR><TD CLASS="quote">I use to run that header on my race car it shows gains of about 30hp to the wheels allowing you tune it for about 17.5 - 1 Air fuel ratio.</TD></TR></TABLE>
your kidding right?
Old Jul 15, 2004 | 12:34 AM
sylvain's Avatar
Default Re: (FerioVtec94)
17.5:1 really ????? How many engine blown ?
Old Jul 15, 2004 | 12:41 AM
type_rev's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xc1097 &raquo;</TD></TR><TR><TD CLASS="quote">by the way i run TODA header w/ TOPFUEL exhaust setup
I'd like to see a video of that!!!
Old Jul 15, 2004 | 07:06 PM
Hacemuy's Avatar
Any more opinions?
Old Jul 15, 2004 | 07:21 PM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hacemuy &raquo;</TD></TR><TR><TD CLASS="quote">Any more opinions?</TD></TR></TABLE>
JDM ITR cat + custom welded 2ndary O2 sensor bung. It won't crap out like carsound ones.
Toda + RM-01 = (Add Mugen Intake and you've got my favorite I/H/E setup )
Old Jul 15, 2004 | 08:45 PM
Jim80y's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (Cosworth)
This is my setup
Old Jul 15, 2004 | 11:30 PM
zeth_an's Avatar
That's the exact setup i wanted jim80y
Old Jul 15, 2004 | 11:34 PM
hadboosttroy's Avatar
comptech race header is a good option. I think you probably will sacrifice a little ground clearance though.
Old Jul 15, 2004 | 11:42 PM
sylvain's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (Jim80y)
Hey Brother in mod's !!!!
If i can give you just one tip, make a 3" pipe between the TB and the Mugen Airbox, it's works very better !
Old Jul 16, 2004 | 05:12 AM
Tweakmeister's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (sylvain)
Please buy me! https://honda-tech.com/zerothread?id=905531
Old Sep 23, 2004 | 05:28 PM
BlueBalls's Avatar
Default Re: TODA Competition Header / Fujitsubo RM-01A (Tweakmeister)
does anyone know where one might be able to get a jdm length cat?
Old Sep 23, 2004 | 05:45 PM
Default Re: TODA Competition Header / Fujitsubo RM-01A (BlueBalls)
Phone up SMSP
Old Sep 23, 2004 | 05:58 PM
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueBalls &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know where one might be able to get a jdm length cat? </TD></TR></TABLE>
I have one for sale Shoot me a PM if you're interested, I'm looking for around $100, stock JDM ITR cat.
Rev4Ever
102
Mar 22, 2007 09:03 AM
John Z
13
Jan 9, 2006 07:11 PM
Declectic
Nov 7, 2005 10:31 PM
ITR3189
Feb 18, 2005 11:54 AM
topspeed86
Sep 16, 2004 05:29 PM
