b18c del sol lost spark, new cap, rotor, wires, and still no spark, WTF?
Old Jul 13, 2004 | 09:15 PM
Ls1 FD3s's Avatar
Default b18c del sol lost spark, new cap, rotor, wires, and still no spark, WTF?
Pretty much like the topic says, i lost spark while cruising around 2 days ago, so i replaced the usual crap and still no dice. Think it could be the ECU? Im not getting any check engine lights. The coil i replaced the old one with is iffy, not sure if it was a good one or not.
I was driving the car at 40MPH in 5th cruising and it just sputered and died. HELP!
Old Jul 13, 2004 | 09:16 PM
Neondc5's Avatar
Default Re: b18c del sol lost spark, new cap, rotor, wires, and still no spark, WTF? (Ls1 FD3s)
First bet would be to replace the coil with one you know works.
Old Jul 14, 2004 | 07:36 PM
Racer_209's Avatar
replace the coil if the dont work replace the ignitor or replace both on the safe side
Old Jul 14, 2004 | 07:41 PM
svmnredracr's Avatar
If all is replaced and nothing works tis a grounding issue usually its the 10mm bolt that sits behind the block by the upper radiator hose, that was my problem
Old Jul 14, 2004 | 09:27 PM
Jimmy's Avatar
Global Moderator
Same thing happened to me except i was on a road trip...turned out to be my ignitor
Old Jul 15, 2004 | 12:00 AM
Ls1 FD3s's Avatar
Default Re: (Jimmy)
slapped my freinds ITR distributor on and the bish fired right up. Prolly my igniter as well, since ive now tried 3 different coils...
Old Jul 15, 2004 | 06:07 AM
SpyderZEX's Avatar
Default Re: (Ls1 FD3s)
I was going to say, check the ignitor.
Old Jul 18, 2004 | 02:28 PM
jwlson's Avatar
Default Re: (SpyderZEX)
The exact thing happened to me.......cruising along, car died.....won't restart= no spark. I still haven't gotten to the bottom of the problem either.
l.holmes
May 18, 2016 11:12 AM
ChrisDaun
Dec 5, 2007 12:43 PM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
