Quick question: Parking Lamp Wires
Old Jul 13, 2004 | 09:09 PM
North_Texas's Avatar
Default Quick question: Parking Lamp Wires
Red = ?
Green = ?
Blk = ?
Problem: When wanting to use turn signal it comes on. But when turning on my head lamps only driver side corner will come on. The reason my passenger side corner got this way was because I before had other corners and the passenger side was exposed "kind-of" due to an accident. So rain would possibly get/did frie the wire that makes the parking lamp stay on. Does this theory sound right?
Question: Beginning of post which wire is which? Also do you think this is correct way to fix my problem. Going to check fuse tomm.
TIA, DixieR3dneck
Old Jul 13, 2004 | 11:27 PM
Default Re: Quick question: Parking Lamp Wires (DixieRedneck)
Old Jul 14, 2004 | 08:26 AM
Answer the damn question..
Old Jul 14, 2004 | 08:32 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DixieRedneck &raquo;</TD></TR><TR><TD CLASS="quote">Answer the damn question..</TD></TR></TABLE>
Well, what type of car is it? I checked my manual, and it lists different colors. Do you have a multimeter? You can get one very cheap and figure out if the wires aren't working properly. I'm assuming black should be ground, but that's as close as I can get you without being there.
Old Jul 14, 2004 | 09:05 AM
dantastic's Avatar
red/blk = parking light
green = turn signal
black = ground
the colors are the same on all the hondas/acuras i've ever worked on
Old Jul 14, 2004 | 11:30 AM
Default Re: Quick question: Parking Lamp Wires (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">red/blk = parking light
green = turn signal
black = ground
the colors are the same on all the hondas/acuras i've ever worked on</TD></TR></TABLE>
Thanks guys. Yes I have a multimeter. Also would the ground wire be the one that makes the parking lamp come on with the head lamps?
Old Jul 16, 2004 | 01:28 PM
Bump..
Old Jul 16, 2004 | 02:04 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DixieRedneck &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. Yes I have a multimeter. Also would the ground wire be the one that makes the parking lamp come on with the head lamps?</TD></TR></TABLE>
huh?
- ground always shows (-)
- red/black parking shows (+) when parking lights and headlights are on, (-) when off
- green shows (+) when blinking, (-) when not
nineohnine
Feb 12, 2011 10:35 PM
hbyrd8701
Aug 23, 2007 08:23 PM
iwhichisme
Mar 25, 2004 11:58 AM
jes c
Feb 11, 2004 01:18 AM
b18bvudoo
Nov 11, 2001 10:40 AM
