signs and symptoms of a bad head gasket
my car drives fine until u drive for over 30mins.. it seems like its getting hot then.. feels slow... drives shitty... its not over heating but just drives shitty.. .. when i restart the car while it is hot, it sounds and shakes like its on 3 cylinder(only does this for like 15 seconds or so..)..... i see white smoke comming out the back.... then it goes back to driving shitty again... I don't lose too much coolent but it goes down slowy...
If the white smoke in your exhaust smells sorta like antifreeze.
If you get oil in the radiator, or antifreeze in the oil... Either one or both.
If you get bubbles coming into the antifreeze overflow bottle when you rev the engine.
If any of your spark plugs look really, really, clean & shiny.
Compression test & leakdown test would be a good way to tell.
deposits on the spark plugs, overheating: https://honda-tech.com/zerothread?id=826259
gray_civic_coupe
Jan 16, 2006 03:15 AM
hybridtech
May 13, 2003 02:47 PM
