ecu chipping
has anyone ever heard of this site http://www.altech.com.pl/wbt/_...1.htm
it is about making your own chips for timming and fuel mapping I just wanna know if anyone has tried this and if it is even worth trying cause it says that a pm6 can be programed to run a dohc zc or even a b20b I just wanna know if it is as good as it sounds and if it is as easy as it sounds thanks
Your stock pm6 can run either of those engines it can also run the soch zc vtec that is what is running the sohc vtec swap that i did for a guy and used a vtec controller for the vtec side of the swap.
